4.0 swap
ratney
Hello. Need help. Put a 4.0 from a 93 explorer into my 84 b2 everything works except I'm not getting any fuel out of my injectors.I have good fuel pressure and fire but won't start. It will fire up with starting fluid. Any ideals?
ratney
Yes. If I spray starting fluid it will fire up for a second.
Ok, so you can rule out crank sensor.
Get a dumb light and unplug an injector. Hook the light to ground and check both pins. One should light it solid. If you hook the light to power and crank the engine the other pin should make the light flash.
ratney
Both pins are hot with key on
That's not right. Sounds like a wiring issue.
ratney
I hooked the solid yellow from the power dist. box to my ignition wire. And the red and green to the red and green from my coil wire
I don't know that is relevant to your issue.
