4.0
shadow88
CLOQUET MN
Well tomorrow I'm going to pick up the donor, and some new parts, and then the 4.0 swap begins, wish me luck!
snoranger
Jackson, NJ
All 10 are Ford
4.0,5.0,4BT,4.0
lchappyjr
Kalama, WA
Good luck, there isnt much to it. Yours should be easier than mine from what I hear. Mine has more power than before even with the 33's on. I swaped all power train and running gear.
country0001
Stillwater, OK
Ford,Ford
You will freakin love it. The B2 was meant for a 4.0
shadow88
CLOQUET MN
Any pointers? Should I pull the 2.9 first or the 4.0? Or don't it matter? I hate wiring so I'm a little Leary
shadow88
CLOQUET MN
Heres a question, my donor is a automatic, my b2 is a stick, I do have a harness from a donor with a stick, should I use the stick harness? Would this eliminate some trouble?
ronclark
Woodland, WA
95 4.0 with 93 ECU
What year is the donor explorer?
you could adapted the automatic to manual. i am going to make a guess a manual harness would be easier. my swap was a manual explorer to a manual truck.
BroncoIIer
Oklahoma
4.0L OHV
I think you will need a computer for a manual because of the neutral safety switch
ronclark
Woodland, WA
95 4.0 with 93 ECU
Both donors are 91
Look on eBay for Evtm's for the bronco II and the donor Explorer.
You never know someone here might have some copies too.
your swap should be a cake walk, most your work is at the white plug that goes into the firewall and its a matter of moving some pins around from what i have read.
I would pull the 2.9L and harness first then install the 4.0, make sure you take lots of photos and notes here things go.
country0001
Stillwater, OK
Ford,Ford
I'm currently runnin an auto ecm . I have a 5 spd. It can be done.Use the harness from your donor, splice in your headlights and tailights. That should cover it.
shadow88
CLOQUET MN
Thanks for the info keep it coming, I'm starting to pull the 2.9 out today,
country0001
Stillwater, OK
Ford,Ford
After you get your 2.9 out. Remove the 2.9 harness. Try to recreate the donors engine compartment in your B2. It'll look cleaner this way. Then install your 4.0
ronclark
Woodland, WA
95 4.0 with 93 ECU
Splice the headlights? I thought the headlights setup were the same on the bronco as the explorer?
The tail lights should no be part of the engine manage harness.
At least it was that way with my 87, I don't remember removing anything for the tail lights in the 93 explorer harness.
Sent from my myTouch_4G_Slide using Tapatalk 2
country0001
Stillwater, OK
Ford,Ford
I used a gen 3 ranger for my swap, had to splice a little.
shadow88
CLOQUET MN
My donor is a 91 going into 90 b2 so hopefully it goes good
BroncoIIer
Oklahoma
4.0L OHV
The headlights will need to be spliced for sure. The explorer ran the wires for the tail lights through the body while the bronco II is run along the frame rail. I don't remember exactly where they tied in the harness at though.
BroncoIIer
Oklahoma
4.0L OHV
Sorry just noticed you have a '90 model. I have an '88 with the older style headlights so there is a good chance you wont have to.
shadow88
CLOQUET MN
So what your saying is, I change the harness from the cannon plug, and maybe splice in the head and tail lights, am I going to have to repin anything at the cannon plug?
shadow88
CLOQUET MN
I've been looking at my donor and the b2 wire harness, the head light parts are the same, so maybe I'll only have to splice the tail lights? Where are the plugs? On the drivers side?
