86 BII air box / blower fan removal
3Stgs
I have searched the forms and cannot find a good answer to this question, but on my 86 bronco II I have a little lack of airflow with the blower in any speed position, and I’m suspecting, according to other post, that I have debris lodged somewhere in that blower fan. Any other advice to why this might be happening would be good, but I think I need to pull that blower out and do a thorough cleaning, I can get as far as pulling the top of the airbox off and the three bolts out, is there an easy way to pull the bottom of the airbox off so I can pull the blower all the way out?
NW Arkansas
I might be wrong but I seem to remember that when my blower fan went out on my 1990 BII that I pulled the fan out from the engine bay and never removed anything from the inside. It was like 3 studs that the fan housing bolted up on the outside with a gasket.
Dennis
NW Arkansas
I think I just removed the clamp and there 2 screws from the bottom of the air box to the wheel well. I do remember it was a pretty straight forward process and did not take much time at all.
Dennis
Two other possible sticking points, heat riser (metal flexible tube) coming from exhaust manifold and the fresh air intake tube that comes from the grill to the airbox. Going from memory the fresh air tube is down low next to the headlight, the heat riser is usually long gone by now but it may still be there. If you live where it gets cold, I recommend you replace the heat riser.
Bub
Just replaced my blower motor/evaporator housing. 86 B2. Had to pull the inner fender well too get to the bottom, inside nut.
Bub
Had a ton of debris that caused the fan to lock up and catch 🔥
