MiniMe
- Aug 7, 2013
- 29
- 1989
I just Bought an 89 BroncoII that has been sitting for the past 3+ years. Going by the oil change sticker in the windshield its been driven about 2000 miles in the past 11 years. It will only run for a second if your spray gas in the intake. I have replaced the fuel pump and strainer assembly, fuel filter and have check the fuel pump relay and inertia switch, all are working as they should. I am getting gas all the way up to the schrader valve(pressure relief valve) up by the intake. If I let sit all day it will start for a sec without spraying anything into the intake. It almost sounds like it is sooo close to starting on its own, a cylinder fires every so often. Any suggestions as to where I should look next.
Thanks
Thanks
