to check if the inerita switch is bad...unplug...just use a short jumber wire on the wire harness to each wire spade. IF it starts...its bad!just an update....
- fuel pump works
- new pressure regulator installed
- fuel reset switch hasn't been tripped
could the PCM or fuel reset switch be bad? how do you check the fuel reset switch?
same location as the fuel relay....IF...still factory units they will/should be color coded...green....brown and grayWhere is the PCM relay?
