Broncoman604
- Jun 7, 2008
- 4
A Buddy of mine has a 88 bronco with the A4LD and when you put it into gear it sounds as if a shaft or gear is grinding, and will not move. It does this in all forward and reverse gears and in both 2,4HI and 4Low. Also it will not hold itself in park it acts as if it's in neutral. Just curious is there a common type of problem maybe a striped or broke output shaft or input shaft in the t-case?
