Yes the ones for the AOD are what you are looking for. The Art Carr site does say its for a A4ld. You will still have to work at fine tuning your linkage but you will have to do that with any after-market shifter. Good luck, a good junkyard may be able to help you get a column that fits your rig with the cables and brackets too, Columns are easy to replace and no trouble to get things hooked up. Not sure what all years but Explorers are RBVs and early '90s are pretty common in most yards. I picked mine from a '91. cable, gear indicator, wheel, shaft, brackets all for under $50.
