ab_slack
- Oct 17, 2011
- 526
- 2
- New Joisey
- 1987
- 2.9L
I had my B2 in the shop last week for a quick swap of rear drive shaft and to get an oil change My B2 is an 87 with a 2.9L, 5 spd manual, and manual 4wd transfer case.
Before going into the shop it was running quite well. It made lots of clicking from the rear drive shaft (original OEM shaft in bad shape). The clicking had been going on for a year and was starting to get noticeably worse so decided it was time. Other than that, it was running pretty clean.
I couldn't locate an OEM drive shaft and found mostly what I think are called GKN conversion. In reading about that my understanding is that unlike the original CV drive shaft there could be vibration issues if spline alignment wasn't good?
From what I had read I was attuned to the fact that it might not be as smooth. Despite the audible clicking, when accelerating hard it pushed very smoothly.
I get it back and didn't notice anything I recognize as vibration in normal driving. Under a hard accel however I could feel some vibration in the stick which was more significant than anything but thought if that was it, no big deal.
But at the same time it didn't seem to accelerate as well. It seemed like...a bit uneven, like there was an occasional miss. I kinda dismissed it at the time cause I can get hypersensitive about the feel, but as I have continued to drive it, it very definitely seems like something is off.
I find I am having to downshift more often. It "feels" like it is just hesitating, low power...like maybe the engine is missing. I would say it feels like a break is dragging but it isn't a continuous sort of drag. It is like every second or two the engine misses a bit and hesitates.
My inclination is to think engine, but the diagnostician in me asks makes me think back to the work done. I suppose it could be coincidental, and maybe they poked some wire or sensor while doing the oil change or drive shaft change, but not knowing the in and out of drive shaft change, GKN conversion, I wonder about that change.
If there were a vibration problem from the drive shaft, how would it seem? Would it be continuous and change with speed? Or could it vary, for example oscillate between smooth and vibrating? Like could the "hesitation" I feel be a result of the shaft momentarily vibrating and steeling energy? During this hesitation I feel something, it doesn't jump out at me as vibration per se but I just don't know what to expect.
Then tonight, I checked the oil level to see if there was enough and found the oil level an inch and a quarter above the maximum. I cleaned and re-measured pulled it several times to confirm. The vehicle had been sitting 2 hours so it wasn't hot (if oil could expand that much in a hot engine). It wasn't absolutely level, but it is the best I have and it is pretty close. I been using that spot for years and never seen this in any of my B2s.
So how serious is the oil level like this? Could it explain the engine being hesitant? Is there likelihood of serious damage in the 300 miles I drove since getting the work done?
Any thoughts would be appreciated. Obviously I will drain some of the oil now that I am aware of it. Just wondering if either of these could explain what I am experiencing.
If these could explain the problem, then I focus on them a bit more. If I am barking up a tree and neither could explain, then I can put that out of my mind and dig into engine to find out what may be up.
Here is a pic of the oil level I measured. The level goes up to where 0 is on the lower scale of the ruler.
