I've recently found that my charging system is not working properly on my 89 bronco II. The previous owner said the alternator was new but I had it tested anyway at local AutoZone good. I then tested continuity and voltage for power at alternator BK/OR and YL/WH wires. Good also. I cleaned and inspected negative cable and positive cable and their respective connection ends. Still no charging. Battery is charged, started at 12.7v, after starting and running the vehicle for 10 mins the battery was down to 12.3v while still running. Could alternator having a bad ground and a poor body ground do this?
