Right on. I got it done. Dd te break lines ready to back it out and the dang fuel pump locked up. After getting it out I verified that it was locked up bought another one got it in. Aaaaaaand no power to the pump. Checked the relay, had power, hit the inertia switch nothing. Then checked, no power to the inertia switch from the relay, but the relay is good. I replaced the relay even though I figured it wouldn't help. And of course it didn't. Straight jumped to the inertia switch from the battery by passing everything, and sure enough the pump kicked on. Cool, I thought, I can just straight wire it with a toggle switch. Then I got to thinking the computer doesn't come on until it gets a signal that the pump is running from the relay, if you cut the relay out of the circuit the computer won't come on and fire the injectors, and sure enough I tried with the pump running and turning the engine over I didn't get any firing. So does anyone know what wire I need to tap into on the computer so it knows the fuel pump is on. Ill just put that one, and the fuel pump on the same switch. I really don't want to dig through all those dang wires to find where the broken wire is.
