Great information, thank you so much for your response and your knowledge. I will now expand my shopping experience. I may also look at pulling a 4.0 flywheel to upgrade my clutch at some point as well, everything I kept finding was saying the 4.0 clutch would only work on the 4.0 of course and the 2.9l, but I was kind of questioning that because the 2.9L is really just a fuel injected Cologne 2.8L as far as I can really figure out, actually the 4.0L is still a version of the Cologne engine as well.The 2.8l has the same flywheel as a 2.9 the 2.9l/2.8l and 4.0 ring gear are the same diameter, the difference being the 4.0l flywheel has more surface area for the bigger clutch.
I agree the block plate might be stretched out a little bit, but it's really the holes in the starter and the holes in the trans that hold the starter in the perfect place. You won't have a 1/4 inch of play in the starter bolt holes. Even if your plate has 1/4 inch of play
The explorer starter is a lot better unit it uses a lot less power and is lighter and half the size.
When your factory b2 starter would not spin due to a low voltage the later starter will work.
,it uses less amps.
The way I look at it is id rather use a new and improved part on my truck then the old style
There is a reason ford didn't put that big old starter on the new trucks, even though it will bolt on the explorer..........
it was a pos, hence the revision.
Hope that helps auto explorers with 4.0 ohv are a dime a dozen in the local junk yards
I managed to find a brand new napa starter for the 25$ junkyard price grab the starter wording for another 5$ and be good to go!!!
