Bronco won't turn off
janco
Harlingen, Netherlands
2.9 i
Hello, my Bronco2 1987 won't turn off, already installed new ignition starter switch. any ideas or tips?
sorry for bad english, i'm from the Netherlands
i see on rockauto a ignition relay, and a ignition starter relay, has that anything to do whit this problem?
grtz Janco
NW Arkansas
Janco
In talking to my guys they suggested you start with the ignition relay. The ignition starter Relay would be what would effect the starter engaging or not engaging. Hope this helps
Dennis
janco
2.9 i
Thank you for the reply, do you know the function of this relay (why it's there),
and where the location is, can't find anything about it in my haines manual
Janco
NW Arkansas
Janco
I would guess it is in the fuse box on passenger side inside the engine compartment. It should say something like Power Distribution Box on the lid. It should be right in front of the Starter Ignition Relay. They are like 10-14 dollars each. Order one of each and replace them both. Disconnect your battery first before replace either.
Dennis
janco
2.9 i
Dennis,
Thank you for the information, i wil order them, and change them both.
you seem to know a lot about bronco's.
i've read somewhere about using tie wraps at the trottle pedal, what's the reason for this?
I have the Eddie Baurer version with electrical shifter for 4x4 and low gear, it's not working:sad:, is there a fuse or something?
grtz Janco
NW Arkansas
Janco
Never heard about the tie wraps. I have manual hubs so not in my wheel house. The electrical shifter item is the very reason I did not want that type of system. I looked and looked until I found the BII that I wanted with a automatic transmission and manual hubs. There way more guys on this forum that know way more then I do about
the BII.
Dennis
janco
2.9 i
Dennis,
Thanks for the info, on this side of the ocean is not so much choice:sad:
but i'm oke whith the stick shift, and happy to have the car.
maybe in another tread, i will ask again for the problem with the electrical shifter, but i'am not going off road anyway.
Janco
Ford Bronco2 '87, Dodge B250 '85
Zip tie fix is for slack in the throttle caused by cable, linkage, etc...
I remember reading about it on full size Broncos, not Bronco II's but I guess it could apply here as well.
janco
2.9 i
Throttle cable
Jerry,
Thank you for the tip, googled it,found it on youtube, en gonna try it .
Janco
