Bruizer 2
higgins lake mi
BIGGER
for a street driven rig, good coils and the eb setup work good. bolt it up and go.
may need different c bushings to tune the ride, but it is as easy as it looks.
makeos
Memphis. TN
5.0 HO
This will be in the rocks, hills, dirt, mud, whatever it comes across. Won't be very much street driving. :icon_thumby:
makeos
Memphis. TN
5.0 HO
Ok I appreciate the helpful information.
higgins lake mi
BIGGER
i am most serious....its hard to not wind up a good running sbf.....and they like to bust shit....i was still busting 60 shit with my 5.0....the 6.5 dont bust shit like my 302 did....
kroussinoffroad
October 2011 OTOTM Winner
marquette, MI
Ferd
hhhmmmmm.......
? higgins lake ? you wheel with sarkozi and them guys ?
higgins lake mi
BIGGER
no.....i pull alot of guys out though...
thats the extent of my wheeling for the most part the last few years...
run the rocks a bit and backside of siren hill...
i need to fix my frame before i can get stupid again...:D
kroussinoffroad
marquette, MI
Ferd
sarkozi is from rosco area. wheels yota's. and he's a big B.S.er. and is know to swear like a pirate.
makeos
Memphis. TN
5.0 HO
Started cleaning up the 9". Got one coat of rustoleum on it.
4.0B2
Walls, MS
4.0 v6
Should have painted it pink'
4.0B2
Walls, MS
4.0 v6
:thefinger: That is all.
So.... No pink? :sad:
Lol. Let me know when you start sas'ing this thing and I'll see if I got some free time. I'd like to be part of a b2 SAS so I've done one by the time I get another 1.
This talking to you on MSJ and TRS thing is getting confusing! :D
makeos
Memphis. TN
5.0 HO
Will be starting as soon as I can gather all parts. Not sure how long that will take. Hopefully not too long.
4.0B2
Walls, MS
4.0 v6
Alright. Just hit me up. Make sure to do a good write up with lots of pics.
higgins lake mi
BIGGER
sorry about the thread jack:D
i think i gave that kid a set of my old bogger/swamper combos some years back:icon_confused:.....he could not believe it when i gave them to him.
but 15's were off the agenda for at least 4-5 years so it wasnt hurting me..
makeos
did you decide on what type of suspension?
makeos
Memphis. TN
5.0 HO
I'm actually ready to order some parts. I'm going to start with the suspension so I can get these things mounted first. Then worry about rebuilding them. Here is what I'm looking at and am open to suggestions.
Wild Horses Rock Crawler 5 1/2" Coil Springs
I don't know if this will be too tall or not. I'm wanting 35s. My truck already has a 3" BL on it. I want to be able to stuff the tires in the fenders and not tear em off.
James Duff Coil Buckets :
"Our proven coil bucket design has been revamped to accept either stock or Early Bronco coil springs for those doing a Solid Axle Swap on their Bronco II, 83-97 Ranger or 91-94 Explorer.
Designed and fabricated in house of 1/4" laser cut plate steel, these buckets completely replace the stock coil bucket and shock mount. Both shocks mount behind the coil for reduced sway, a smoother ride, better tire clearance and articulation. Will work with the stock sway bar. Bolt on design, no welding required. Blue powdercoated for long lasting good looks. All new parts, No core required."
Trac Bar : Wild Horses 66-75 Trac Bar Drop Bracket
Would this work?
makeos
Memphis. TN
5.0 HO
Also plan on doing the f250 shock mount.
I like these radius arms, but not the price:
Stage 3 Tubular Long Travel Radius Arms
Ford Bronco Long Travel Radius Arms. Ours are the only Early Bronco Radius Arms to utilize 2" diameter, 1/4" thick heavy wall tubing, cast iron head units, and massive 1" bore high quality Rod Ends for maximum strength. Arms are designed with built in caster, offset to clear larger tires and tight to the frame rail to improve ground clearance. 10 3/4" longer than stock—Moving the pivot point farther back vastly improving suspension travel and articulation, overall handling and control for on road driving. Built in lower shock mounts for use with stock shock mounting position or our Stage 2 Hoops and our Long Travel Shocks for 15" of travel. Best results are achieved when these arms are used in conjunction with Duff suspension components. Blue powdercoated for long lasting good looks. Requires reuse of original C-caps. Includes arms, head units, rod ends, bushings and all necessary mounting hardware. All new parts, no core necessary.
Still don't know if I want to buy extended arms or build/have some one build them.
ThatGuy
Oak Ridge, TN
Since you are using mostly Duff stuff I can tell you my real world experince. Mine was a 91 Ex using the 5.5" EB springs and Duff buckets.
I got aboout 7"-8" of lift and it rode excellent. I tried the 3.5" springs but they were way too soft for a daily driver.
There is a guy around here that has your exact same setup (B2 w/ 302) and he is running the 3.5" springs and says it is fine.
Either way, I'd lift it and ditch the body lift. You can run 35s with either setup, just depends on how much you want to trim.
If you copied that info from their site, it's wrong. The arms are .313 wall. You would need the kit for the C-channel frame. The one you have listed is for the EB w/ boxed frame.
makeos
Memphis. TN
5.0 HO
I'm not decided on the arms yet. I think I may just order it all from duff..would save me on shipping. But I've heard the wild horses springs are a little more flexy.
higgins lake mi
BIGGER
looks like a solid plan.....coils are usually try and see...:icon_thumby:
