cable battery
freddie2
hi guys,
i want to change my battery cable for negative part. But i don't find the same cable...
mine have 2 little cable, and standard cable don't have this...
I don’t know what these wires are for?
my cable:
15256
standar cable :
15257
freddie2
hi, nobody have this cable on Bronco? really?
duffy
I haven't "looked" at mine all the way from end to end but the battery end looks like what's on my 89'. Of the two smaller wires by the battery the one with what looks to be a plug is for the ABS ground. If not hooked up you will have "rear ABS" light on and the parking brake light will stay on. The previous owner wanted his battery back when he delivered the vehicle to me. I never noticed that plug and ended up chasing my tail trying to find out what was keeping those lights on. The other one is also probably an aux ground.
freddie2
thank you very much !!
i dont' find the same cable for change, have you idea where can i fond this? (with two little wires)
ecgreen
New Hampshah
Those little wires are just grounds, so you can use the same gauge wire and make your own. The plug is a ground for the ECM I think (but don't quote me). If you can't find a plug, I don't see why you couldn't hard wire it.
freddie2
thank you, i will try to change the negative batterie cable, when i have time.
duffy
I would suggest trying a NAPA if there is one near you. They carry more "stuff" than any other parts house.....JMO, I don't work for them.
freddie2
