Cheap Custom Steering?
leseman1
Washington
I'm getting tired of tolerating all the bumpsteer i'm having in my bronco, so i was looking into alternatives to the stock steering linkage. I had been thinking about doing the super runner set up until I seen the stone crusher style set up. I dont care for the heim joints though and have not been able to find any contact info, while doing research I came across this http://www.ruffstuffspecialties.com/catalog/YLINK.html Im thinking of using it backwards from its intended purpose similar to the way the stone crusher set up works. Does any one see a reason why this wouldn't work?
swynx
lewiston idaho
Mazda
That's not what comes to mind when I hear cheap.
Bobby Walter used xj steering junk. The zj is the same only twice the diameter. So stronger. He said it worked fine. If I could find his "build thread" I would link it. Maybe hell chime in.
1RangerNut
Central,IL
It's still cheaper than the Superlift kit.
4x4junkie
Mall-Rated
So. Calif (SFV)
I'm not convinced the Stonecrusher style setups are any better than the stock junk other than it saving a lot of wear & tear on you tires. Though I've yet to actually drive something with the Stonecrusher setup, there's been a good number of reports floating around of people still experiencing bumpsteer (something i don't notice with my K-link (Superlift) setup that has the centerlink repositioned where it belongs).
