spdcrazy
- Mar 8, 2008
- 173
- 2
- Age
- 36
- Homer, alaska
- mostly 86
- B2
- 2.9 bored and cammed
Ok so the next project on the B2 is a chevy leaf swap UNDER the frame. I picked up a 8.8 the other day so I need to weld on the new spring perchs and shock mounts. I have more research and measuring to do but I have a few questions i'd like to get answered while i'm learning. I plan on a reverse shackle setup on the back and a standard pivot point up front. Max flex is the goal. Not sure if I want to do a 63 or 64in because i'd like to keep the axle position the same so I don't have to do anything with the driveshaft or wheel wells. Ok here's a few questions for ya, sorry if they seem kinda scattered.
1.assuming a 63in leaf, should I look for a 1500 chevy spring or a 2500, etc? Something light weight? And with the suggested leaf, whats the eye to eye measurement with a load on it, hopefully the load of a chop top b2 with a light 4point roll bar, but I can prob make it work if I had the measurements on a ranger or something similar.
2.What angle should the shackle be on the back with a load on it? I assume it needs to angle to the center of the leaf a bit, but how much? I plan on using a custom length shackle, similar to the 6400 beltech. But that will change when I get everything together, so I can attempt to get the ride height I want, as well as a good amount of flex.
3.On the brackets to hold the leaf on, I plan on cutting them myself and having a shop weld them up due to lack of a welder and trust in my welding too. What thickness should I look at? 3/8in? Mild steel I assume. And should the regular pivot piece be one single piece of steel and bent into a U or three pieces welded together for the U shape? I don't plan on any amount of drop on the front pivot point FYI.
4.If things work right i'll be at about 6in of lift (plus or minus 2in, i'm not real picky) so what is the general rule of thumb on pinion angle? And how do I set that without knowing exactly the ride height with a load on it?
5.Should I consider boxing the frame where the brackets will be for the pivot points for the leafs? Its no desert racer, just a rock machine with little highway use, but if it should be done now is the time.
6.on the shock mounts, I messaged dan from ruff stuff a few days ago, waiting on a response, but maybe you guys can help. I hate how the stock 7.5 had the shock mounts that hang below the axle housing, is there any negitive effects to mounting them level with the axle so they don't get smashed by rocks? I would keep the stock configuration of one in front and one behind the axle. does anyone make something that I could use, or would I be best just fabbing them myself?
