D44 Homework for a 92 exploder sport
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
sometime during summer i would like to SAS my exploder. from what i read a D44 would be best. i am keeping the stock 8.8 for now. i will check my axle code tomorrow for my ratio on gears. my main question is wich 44 has the same bolt pattern as my 8.8. i kno i want a open knuckle 44 beacuse (from what i read) they are easyer to maintain and offer tighter turning. correct? any advice would be greatful.:icon_thumby::icon_welder:
AKBroncoII
None will have the same bolt pattern. You are stuck with either getting different rear shafts with 5x5.5" pattern, running adapters, or swapping your rear out.
Sunk
Everett, WA
AFAIK, the D30 is the only solid front axle available with 5x4.5.
Sasquatch_Ryda
Coast Mountain Crawlers
Terrace, BC, Canada
4.0L/4.0L/6.4L
Some 1/2 ton dodge d44's will have the small 5 on 4.5 bolt pattern, but they have cartridge wheel bearings and no hubs IIRC.
crawlin91
Crawlorado
I would do full width hi pinion dana 44 and a full width 8.8(f150) or a 9"
rangerguy1996
you can swap ur rear axles for 5 5.5 for like 300 bucks and they will be alot stronger than stock 8.8.
ziptie
Houghton, Mi.
I am running adapters on my 8.8 after swapping an early bronco dana 44 into my ranger. I don't recommend them where they have been coming loose and snapping wheel studs. I will be spending the money and getting the custom 5x5.5 shafts.
wahlstrom1
J-man HD Mech
Edmonton Alberta
It all depends on where you get your adapters from. I had mine built by a fellow forum member and they have yet to lose an inchpound of torque since I first installed them over 20,000km's ago. I'd reccomend talkin to Racin' Ranger on RPS if you wanna go that route, but I've had nothing but good luck with mine!
-andrew
dusto2
scv ca
wait i thought newer jeeps have a d44 option that has the same bolt pattern as a ranger/explorer and are almost the same width
wahlstrom1
J-man HD Mech
Edmonton Alberta
TJ rubicons have a hybrid D44, mostly a modified D44 centersection with D30 unit bearing outers etc. The new JK's have a 5 on 5 bolt pattern.
-andrew
dusto2
scv ca
cool thank you for the correction, i didnt relize that never looked into it that much other than reading that they offer a d44 as an option.
ziptie
Houghton, Mi.
Andrew, are your adapters made from steel or aluminum?
