I swapped a 92 dash into my 86 b2, along with the 4.0 , basically you need to gut your b2, it will be easyier to use the newer steering colum and brackets but not nessesary, I used the first gen column, the only wiring that will need to be spliced or swapped is the 4x4 engagement dash lights 2 baby blue wires on with black stripe
Gas guage and fuel pump, and taillights n running lights, all those connections should all be color coded correctly, and the splicing will be at the drivers side frame rail under the brake booster, you'll have to figure out your headlights, as I swapped a 2nd gen front clip on as we'll, it's not to hard, just remember how you took the 92 apart and look at the differnces, I had to melt the upper blower vent housing to fit around the old style steering column, but if there is a will there is a way, good luck an if you need any help send me a pm.
Sent from my iPhone using Tapatalk -
now Free
