TomAZ89
- Jul 30, 2023
- 6
- 4
- 3
- 1989
- Ford Bronco II
1989 Bronco II Manual Trans.
Hello All I have run into a problem with the driver side dash turn signal indicator light as well as hazard light not illuminating on the dash. Passenger side indicator on dash and lights are working properly. I have searched the site and taken some advice on things to check.
When turn signal is turned on they do work on the outside of the vehicle. When the Hazards are turned on they work on the outside of the vehicle. Just left indicator on dash is not lighting up and blinking...just blank.
Tested all fuses. Checked driver side bulbs. They are all working and blinking. Had a spare flasher and just swapped that in even though the flasher was working fine on outside of vehicle.
For reference this cropped up after I had a new starter installed....not sure if this could be related to that.
Anything to check would be appreciated. If I have to replace the bulb in the dash. How difficult is that to get to? Can I access it by remove trim piece or do I have to take the column apart?
Thanks for any suggestions.
