TeamExploder
- Dec 24, 2007
- 155
- McClure, Pa.
- 94,96,00
- FORD
- 4.0 OHV+SOHC
I'm going to make disconnects for the front sway bar. It is the Skyjacker lift.
Talked to skyjacker and they said I need FA400, said that FA600 was only sold for 8inch kits.
Ordered the FA400 or FA600? Anything over 4" lift needs the FA600, or the stonecrusher/super-runner setup.Went to the local 4wd shop and ordered one. Thanks for everyone's help.
The guy I talked to from skyjacker told me I had to get the FA400.....so that is what I ordered....If it doesn't level out then I'll have it sent back and get the right one....Skyjacker told me that FA600 was for the 8inch lift kit.Ordered the FA400 or FA600? Anything over 4" lift needs the FA600, or the stonecrusher/super-runner setup.
Here are pictures of the steering setup. I've IFS for so long but this all looks correct to me.
That's some pretty bad steering geometry. The tie rod should be completely horizontal/parallel to the axle beam. Do you have the FA600 pitman arm? It doesn't really look like it. If you don't, getting that would help. However, you may need to upgrade to a new steering set up, like the Stonecrusher steering.
Yep yep, that'll be your problem.Ooh... No wonder you have bumpsteer... This article explains it all very well...
http://www.therangerstation.com/Magazine/winter2008/steering_tech.htm
I think what he was getting at is guys have done the same thing you just did and they ended up needing to get the FA600. Either they needed it to get the alignment right or needed more drop in the steering linkage, but what do I know:icon_confused:......I don't have a lift in mine yetThe guy I talked to from skyjacker told me I had to get the FA400.....so that is what I ordered....If it doesn't level out then I'll have it sent back and get the right one....Skyjacker told me that FA600 was for the 8inch lift kit.
