EFI problems.....?
Dishtowel
August OTOTM Winner
Grande Prairie , Alberta, Canada
So, 5.0L from a 1990' TownCar, with AOD into my 86' B2.
Mounted, fluids buttoned up. Wiring spliced to Bronco, Plug in the EEC and hit the key. VROOOM.
Very exciting.
BUT it starts alright and runs, good enough to drive it 10 min into town for exhaust. It did not want to run well enough to drive home from exhaust. I re-set the EEC, then was able to drive home. I was NOT happy with how it was running.
Started investigating. Pull 1 spark plug wire off the distributor and see what changed. When I pulled 7 of the 8 wires it made a dramatic/noticeable difference. The #4 cylinder nothing changed, it was still getting spark, but having that plug wire disconnected did not change how it was running (which was poor to begin with) (BTW all spark plugs where gross with soot, I think it was over fueling due to #4 not firing and just cycling oxygen onto the O2 sensor)
So, we have spark to #4, obviously time to investigate fuel. Pulled injectors, sure enough #4 was gummed right up. Pulled and cleaned all injectors. Re-O-ringed and re-installed injectors (vegetable oil on the O-rings). Reassembled intake and all that junk. Turned the key. VROOOM
Very exciting.
It ran way smoother and sounded much nicer. For about 5 minutes. :annoyed:
Then it began to get worse and worse, back to the point of running like a bucket of garbage, like it was before all the injector work.
SOOOOO obviously the computer is getting problematic information from somewhere! Everytime I re-set the computer it runs awesome, for about 5 minutes, then continues to get worse. These comps fun of averages (right?) so it is getting a signal to do something different, which is making things worse.
ANYBODY GOT ANY IDEAS WHAT MIGHT BE GIVING ME THIS BAD INPUT?
PS: all the emissions trinkets on the passenger side of the engine are gone. A: no space for them B: why would I want that junk?
Could it be that this emissions junk sent the comp some sort of signal that is now absent that is now screwing me?
Dishtowel
August OTOTM Winner
I want my EFI
I think it is the superior option because I am an serious offroad rig. And because (well this is whats supposed to happen) once I get it running there is no more fussing with it!
1989GT
Cincinnati,OH
You need to pull the codes from the EEC, otherwise you'll be shooting in the dark.
igiveup
Edmonton Ab. Canada
Hello
A code reader for that ecm is $50 cdn at Canadian tire in Canada. These ecm are the older type before orb came in. Do you have a hand held volt meter? If you do try this http://therangerstation.com/tech_library/OBD_I.html . This test is good on computer controled ford cars with eec-iv from 83 to 92-95 (depending on model). Let us know what happens. Is this motor a H.O. or S.O.? Did you switch parts switch any parts from different 5.0?
igiveup
Dishtowel
August OTOTM Winner
I'm at work till 5 moutain time, my dad just called me from home, he was bored and messing with it.
He pulled the ThrottlePositonSensor off and checked it, all appeared to be in order. Ran it again = poor.
He pulled the TPS off and opperated it with a skrewdriver and BAM dramtic results. First it stalled when he turned it fast, then when he turned it slow it improved to the point of running correctly.
So, spark system appears to be good. Fuel system appears to be good, TPS is suspect!!! Anybody have any experience with them?
Hello
igiveup
Thanks for the input man! Good to know a code reader for this thing is cheap. But I dont have very much faith in that "code" system. Once I get a code what do I do with it? Is there a code legend on the back of the box? How indepth is it?
For $50 i might just pick one up thought. Probably cant' hurt.
(S.O. engine, stock, original parts. It got a poor-man rebuild (hone and new cylinders))
1989GT
Cincinnati,OH
Get a voltmeter and probe the two wires going to the TPS. Turn the ignition switch to on, but don't start the car. Adjust the TPS position until it reads .9-.99 volts. At WOT it should not read more that 5 volts. Also operate the throttle body thru it full range of motion to make sure you get a smooth increase from .9 to 5 volts. Any spikes or dropping to 0 and the TPS is bad. Good luck!
igiveup
Edmonton Ab. Canada
Hello
Try http://forums.corral.net/forums/index.php . These guys can help you on the computers and changing the motor to a H.O. if you want. It is a mustang site but the computers are simmilar. The codes will be the same between H.O. an S.O. motors. They have helped me in the past with my computer codes and problems.
igiveup
Dishtowel
August OTOTM Winner
Thanks for the input guys!! I will defiantly be testing that TPS sensor. Luckily I have a spare intake manifold from the junkyard so I have two to work with!
Dishtowel
August OTOTM Winner
ARGHHHHHHHHHH
The TPS sensor that was ON the engine did not pass test. Idle it measured 0.34 volts, WideOpen it measured 3.14 volts = fail
The 'spare' I had measured 0.6 at idle and 4.7 at WOT. = Mostly pass?
Pulled and cleaned O2 sensors.
Put everybody back on, (the 'better' TPS sensor) and it ran significantly better. Not 100%, but much better. For about 3 minutes :annoyed:
At about 4 or 5 minutes it has deteriorated to the point of it kills itself due to some sort of random large hickup.
WTF, EFI is losing favor....
Where else to look? Where/who is sending the EEC bad information??
(I dont have a code reader for now, and again I ask, once this thing tells me a 'code' what do I do? How do I know where to look?)
igiveup
Edmonton Ab. Canada
Hello
Get the codes and let me know the numbers. I have a book here that goes in depth on the codes and let you know what they are. The codes aren't perfect but points to the area that could be the problem.
Now it could be a simple as a bad ground.
How did the car run before the motor went in the B2?
igiveup
Bruce
Southwest Missouri
4.0 SOHC
Check your fuel pressure also we had problems similar to that and fuel filter and fuel tank was gummed up. Fuel pressure would gradually fall off you need between 35 and 45 pounds of pressure.
Dishtowel
August OTOTM Winner
THANK YOU GUYS FOR YOUR INTEREST AND CARE
I appreciate it!!
What do you fella's know about O2 sensors?? If there is some paint on the outside of mine might that effect how they operate?? I have been reading on them and I'm begining to believe that they are some sort of chemical difference (producing a voltage) one side of the equation measures the oxygen OUTSIDE the exhaust then the bung in the manifold measures remaining exhaust INSIDE the manifold. The comparative value helps the engine dial in how much fuel to input to achieve the desired stoichiometry.
Thoughts?? (Mine have SOME engine enamel on the outside from when I painted it on the stand, I am going out to clean them after I hit "submit")
Hello
igiveup
Thanks for your help! I may get a code reader tommorow if I'm still haveing grief. What am I looking for when I head to Canadian Tire? Any specific brand?
How did it run before? It didn't. I got it from the Pick-N-Pull in edm, the whole car. It was gross, the engine was full of shit, the trans was COOKED. Epic fail, but it's been rebuilt, and re clutched, and this leaves me in the dark looking for problem areas.
Hmmmm, good input. My 2.9 that I pulled didn't seem to have any fuel problems...
How would I check fuel pressure? There is a "valve stem" very similar to what is on tires on the top left of the fuel rail, check there?
Bruce
Southwest Missouri
4.0 SOHC
Yes that little valve is the fuel pressure tap port, not sure what is available out there for a gauge set to check it i just happen to a fuel pressure gauge set.
Paint on the out side of02 sensors shouldnt effect it,if you have a volt meter put the positive to the black wire(you will need something to pierce the black wire to hook meter lead too) on the 02 and the negative volt meter lead to ground on battery, when engine is warmed up sensor should read between .1 volts to .9volts. Also you may need to check 1 of the white wires to be sure you have 12 volts to it whenkey on since 02 sensors are self preheated.
Dishtowel
August OTOTM Winner
I cleaned them shiney-new and reinstalled.
Still same thing.
http://video.cardomain.com/Clip.aspx?key=084C518583A30154
I tested them on the workbench with the propane torch and they checked out. One was a-bit slower to respond, but they both operated. Once they where HOT they read 0.9 volts, and by backing off with the heat you could make it read anywhere between there and 0.1
Back to square 1
At least I have a few knowns....
1989GT
Cincinnati,OH
It should run fine like this.
Is this engine Speed density? I thought the 90 town cars were Mass air. Was that video of a warm start or cold. It's hard to tell exactly what's going on with the background noise but it looks like it ran well for about 30 seconds, started missing and then died.
higgins lake mi
BIGGER
what sytem are you running exactly? was it all from the same vehicle?
if your running a maf system with no air meter then its not gonna run well after warmup...generally wont run before so that does not seem likely.
but i cant see or hear what you have. so no way to tell.
but...code reader? a 40 dollar code reader isnt worth buying, not on an obd1.
i just switch the sto to ground and watch the check engine light light. did you hook up the light? if you didnt just use a test light.
checking the o2's at the pins where they interface with the pcm is what you want to do, at least you know they work off the car, plug them in and run the car and see what they are reporting at the pcm.
buying a fuel pressure gauge is what you want to do with obd1, not a stupid base tester imo as the money spent on the fuel pressure gauge is better spent, where base code retrival is free.
if this is a mechanical issue then you have one thing, if it is an efi issue, from what you have reported it seems its all in closed loop.
so map sensor will be key for sd and maf for maf.
what exactly do you have system wise with pcm code, and how did you wire it to the oem harness?
also, the spark plug test should be after a cylinder balance test which your pcm should run. do that test and get all codes so far before any reset, and then reset, run and recode.
this will go a ways towards isolating issues.
Dishtowel
August OTOTM Winner
Speed Density.
Warm start, but the computer was not 'freash', I had run it 2 times before, and the first time it runs better for longer, but ends up doing the same thing. The background noise is the shop exhaust fan for engine exhaust.
IDK how it goes from running to missing bad enough to kill itself is such short order. It has factory plug wires, lol. perhaps those need replaced? They say 1990 right on them.
I am running SpeedDensity from a 90's towncar. STOCK, all from the same donor car, I got the whole car from the pick_n_pull.
I know which wire is the check engine light, I will have to wire a bulb to it.
I will follow some wires from the O2 sensors to the EEC, (when you say PCM do you mean EEC? engine computer?)
Fuel pressure gauge is on the list.
When does it switch over TO closed loop? What can I test to see when it is switching over?
I have my MAP hooked to manifold vacuum and plugged in.
I hooked up about 12 wires to the OEM harness. I have it all written on a PDF document, I could post/share it if I knew some way to make it available for public download. Otherwise you have to PM me your email and I can sent you my 'answer key'.
IDK what you mean by spark plug test, (Pull them off one at a time and see what changes?) and IDK what a cylinder balance test are either.
THANK YOU GUYS FOR YOUR HELP AND INPUT!!
higgins lake mi
BIGGER
poppin the plug wires off looking for a dead cylinder can be similarly done with the pcm(eec)...it will do it for you after you get the engine codes while the engine is running. you wait for all the codes to come back, and then run it to wide open throttle for a second and let it do its thing, it will then report back what cylinder/s if any is/are being a lazy bastards. that will help guide you if you have some sort of injector issue or where to look for low compression ect.
generally after 2 minutes it goes closed, you know its doing this cause thats when it runs like ass.
how does the vacuum look? should be pullin 16 or so with no flutter.
did you hook pin 30 up to crank power? this can be important for full run, but it varies. and i dont know why. we had some great dt's here too its all in the base program the way i understand it. its possible the o2 harness isnt grounded along with the heater circuit not having key on power if it is having issues fueling due to o2 information.
so knowing how its hooked up is pretty much necessary.
Dishtowel
August OTOTM Winner
AirChargePressure = ACP
BarrometicPressure = BP sensor
I dont know if I have these installed. I dont recall them. Where do they normally live in relation to the engine??
Could I even run I didn't have them?
