azazeyl
- Mar 4, 2013
- 13
- 85
- ford
my truck runs fine, so none of this is truely important. but wires drive me INSANE. i hate to see them and hate having alot of them. i have these wires that i suspect very strongly are not OEM and therefore can either be removed or replaced with something much simpler. it starts with a black box under my dash. it feels like there is a fuse on the side that faces away, but i cant get that far in to see it. from what i can see, one set of wires runs to my brake switch labeled "brake switch hot wire", and two green wires (oem) go from there twards the fuse box out of sight, this junction is wrapped in electrical tape. then there are more wires that run into a plastic cylinder.this cylider has a cable that is runs and ties into my throttle cable, this is mounted just above my brake booster to the right. then two more wires run down the body to a sensor (that i cant find online) that reads a magnet off of my driveshaft. what are these things, and can i rip them out? thank you for your input.
