Broncopower33
- Feb 3, 2009
- 81
- Ramona, Ca
- 1990
- 4.0L
I got an 8.8 out of an Explorer for my 89 bronco ii. I'm in the process of welding in the spring pads as well is finding the pinion angle. I'm running explorer leaf springs and 3" blocks. I have the axle hanging with drive shalf on. Right now the blocks are not welded. The angle of the drive shalf right now is 22 degrees and the axle or pinion is also 22 degrees. Is that angle ok, can I leave it at that position????? I saw in the tech library somthing about 6 degrees, but I dont see how that works. I checked my other broncos and the drive shalf is around 20 deg with a stock 7.5 rearend? Need and info..
Thanks
Thanks
