Everyone that has said you don't need gasket sealer is only partially correct.
It actually depends on what type of gasket you are using. It is true that most modern, high quality gaskets don't need any sealer.
However, if you bought a cheap gasket set full of old-style paper gaskets (I just used one 2 months ago on a budget build), you'll definitely need gasket sealer. The stuff I use is called "High Tack". It's a sticky purple liquid substance and comes in a can with a brush attached to the lid.
Again, rubber and plastic gaskets generally don't need sealer. Paper gaskets DO need sealer. Also RVT silicone IS NOT gasket sealer, rather it is gasket MAKER. Using RVT silicone as gasket sealer will never work well. Using RVT silicone as the gasket itself, works OK in some situations (I've had good luck on thermostat housings and intake manifold joints when I was too cheap to buy a gasket or the store was closed, etc).
