are gauge clusters on same year B2 interchangeable? I have 87 b2 w/o tach. also have 87 b2, donor veh, w/ tach cluster. is this simple swap? thanks to all
The wiring harness is different so it's not a plug and play swap.
I wanted to do that very swap only with a Ranger but didn't want to do it bad enough to modify the harness.
I just swapped a cluster with a tach out of my donor 88 B2 into a 92 ranger and everything hooked up right and works good. you just have to drive it a bit for the tach to get...... calibrated?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
