help with stuck caster bushings
Harley
Oregon
yesterday did not go well...the special fork i bought did not remove the camber bushings and i resorted to cutting one of the lips off of the bushing and now im drilling it out! slow going as i dont want to damage anything...what a day! anybody have any ideas for when i get to the other side???
4.0B2
Walls, MS
4.0 v6
heat... lots of it.
4.0B2
Walls, MS
4.0 v6
spray it with something like PB.. or mix up some trans fluid and acetone and keep it wet from now till you're ready to try it.
Harley
Oregon
Will a little propane torch work?
Sent from my SPH-L710 using Tapatalk
4.0B2
Walls, MS
4.0 v6
better than nothing... but it'll take longer..
I use my oxy/ace torch.
Doofy
Glennallen, Alaska
Try Mapp gas, instead of propane. It is a mixture of acetylene and propane and gets much hotter.
Harley
Oregon
Never heard of that...where do you get it?
Doofy
Glennallen, Alaska
Any hardware store that sells the burnzamatic torch or the small propane bottles for them.
Doofy
Glennallen, Alaska
I don't remember if the torch heads are the same or if the bottles interchange. Mapp gas has a 5300° flame and propane about 2300°.
Jsommers
michigan
Just pull the bolt out and pound a chisel in to spread it apart an spray it with pb blaster. The big channel locks and try and turn them and pull up at the same time
Harley
Oregon
Isn't the bolt part of the ball joint?
Jsommers
michigan
Mine has a pinch bolt that pulls the two parts of he beam together and pinches the camber bushing and the balljoint is in the center of the camber bushing.
4.0B2
Walls, MS
4.0 v6
they all do...
Jsommers
michigan
Well then no. The pinch bolt is not part of the balljoint.
Harley
Oregon
Harley
Oregon
Got one out...I don't have a pinch bolt unless your talking about the top nut
4.0B2
Walls, MS
4.0 v6
I'm pretty sure my D28 had a pinch bolt.... post a pic or 2 of it.
Harley
Oregon
Checked again and no pinch bolt...hands were too greasy to take a pic...
PetesPonies
east coast
I have removed a lot of bushings by burning them out. It makes a smokey mess, so make sure you are outside. But once the bushing is out, you just drop it in a bucket to stop the burning. Easy.
