- Jul 24, 2016
- 351
- 40
- 28
- NW Arkansas
- 1990
- 2.9
- Suspension Style
- 4wd
- My credo
- Do what you can with what you have where you are
So I have a 1990 BII with automatic transmission and factory AC. I have developed a crack in my radiator which has the transmission fluid cooler. I have ordered a new radiator, water pump, upper and lower radiator hoses, thermostat and 3 new belts. My question is when I disconnect the transmission cooler lines how much transmission fluid will I loose? I want to make sure I have enough fluid on hand to replace. I will do a radiator flush before installing the new radiator to flush out the system. Thinking 2 gallons of antifreeze on hand should be enough to refill the system.
Thanks
Dennis
Thanks
Dennis
