1BadRS
On my 84 I have a solinoid mounted on the fender and then just one wire that ran down to the starter. When I swapped in the M5OD trans with matching starter it has the big thick wire and then a spade connector. Right now I have the fender mounted solinoid hooked up and then just the big wire running down to the starter. I have nothing on the spade connector at the moment.
When I turn the key it just clicks but doesn't try to start the truck. Does that spade connector at the starter need to be hooked up as well? What wire do I want to tap into?
thanks
thanks
