- Jul 25, 2009
- 98
- 1
- Ft. Lewis, WA
- 1984
- ford
- 5.0 V8
EDIT: UPDATED 6July2010
Specs:
1984 Bronco II
Engine - 340hp 5.0/Derale fan/3core rad, hand throttle
Drivetrain - fully built C5/artcarr rock-gate/1354/1354M Doubler. HP60F: 5.13/Spool/4340 35spline inners and outters/Slugs/Hi-steer/Ballistic cover/Ram Gaurd/PSC full hydro steering w/ saginaw pump. D60R: 5.13/spool/35spline shafts/Ballistic cover
Suspension - Trailgear leafs, 104" WB, Rancho 9012's, Blue Torch 4ply limit straps
Tires/Wheels - 40" iroks, marsh racing 15x10 beadlocks
Armor/body - halfbacked/dovetailed/fully caged, flatbelly skidplate, stinger bumper
Lighting/Electrical - composite headlight housings w/ silverstars, hella 5900k driving lights, 4" rock lights, 4" LED tails, Dual Optima yellowtops, 2000w inverter
Fuel - 8.5Gal JAZ fuel cell with rollover valve and Walbro pickups, electric fuel pump
Recovery - Warn M8000 winch with 100ft synthetic rope and spidertrax alum. fairlead
Seating - Corbeau seats with 4pt harnesses
Extras - On-Board Air 150psi max, jerry can, ammo box storage, Uniden 510 CB radio
Ive never made a build page here on TRS so I figured I would beings I am about to get the building process kicked back into high gear so I have somewhere to consolidate it rather than the show-off forum. I had a fairly detailed build at rrorc so I will just cross post straight from there without editing for the purposes of Tech, and the add on from where I left off.
basically... this is how my B2 has been for quite awhile..
dana crappy in the front, ford 9 in the rear. locked both ends. doubler.. 35's.. blah blah.
been collecting parts for quite awhile and just in the last week decided i need to get this thing done finally so i started dropping some cash on stuff to get it done.
tires
60's front and rear... front is from 97 F350 which i got free last november, rear is from 84 or something F250. 35spline, 5.13s, welded.
had an electric shift on the crawlbox for the last 2yrs.. got sick of the motor fawking up, having to manually shift it from under the truck half the time. finally found a manual 1354...
pulled crawlbox apart the other night to inspect/clean up.
Mated the cases together, welded a nut to the shift lever and a bolt to the bottom of some 1/2" solid rod i had laying around.
Trail-Gear leafs front and rear
the fronts will push me forward about 2.5". the rears with some bracket relocation will push me back 7"-7.5"
Ballistic delivered covers and thread inserts/heims today..
ran out of wire just as i was finishing up.. hate when that happens.
finished the t-case stuff up last night. that shifter was kind of a bitch to make.. but I got it done.
has 3 bends in it. one of which goes 2 ways in the same spot.
got a shift handle for it and here we go
may add a boot or something.. or maybe not. in that picture its in 4low. when in 2hi it lays all the way back.
filled up all the cases w/ amsoil and hit the trail today for a little bit of a shakedown. it is so much nicer with a manual rear case vs electric.
oh and btw, i found the spring hangers, ford still sells them, they are roughly $35 each... alot more than i wanted to spend on them but... $140 is worth it instead of having to go grind some off i guess.
Specs:
1984 Bronco II
tires
