pawpaw13
- Apr 29, 2009
- 3
- N.W.Georgia
- 1990
- ford
- 2.9
I have a 90 bronco 2 with a 2.9. Heres what I need help with. The truck runs great most of the time but sometimes it will act like it is running out of gas or has a short of some kind. It will finally die and you have to let it sit till it cools off and it will start back and run fine till the next time, which might be a day or a month later. It gives you no warning it just starts missing and dies.This has been going on for over a year now. I have dropped the tank and made sure the pump filter was not clogged. I have checked and cleaned the seniors on the uppur intake manifold. I've had the wiring checked by someone that seems to know what he is doing. He downloaded the codes and found no problem. I have replaced the fuel filter, coil, plugs, plug wires. dist. cap, rotor button, pick up in the dist. tfi module, fuel pressure regulator. I'm planning on giving it to my daughter for graduation, but I would like to know its going to get her back home when she leaves in it. Any ideas would help. Thanks
