No power
Ok, lets start from square one.
What have YOU done to it? I don't care what you were given receipts for, or what he said has just been done. What have YOU done to it?
birddog321
Buford, GA
Plugs and wires. Checked the timing. New MSD coil. Seafoam treatment. Checked all fluids. Tomorrow I'm changing the fuel filter. And rechecking the fuel pressure.
shane96ranger
Utah
4.6 Triton / 5.0
In case you didn't know, you'll want to get your FP reading without vacuum. Just plug the line with a little bolt or something.
shane96ranger
Utah
4.6 Triton / 5.0
Which hole.
This is weird. I replied to this a couple hours ago, and now it's not here. That's the second time that's happened to me this week.
Anyway, you'll want to plug the vacuum line off. You don't need to worry about the port on the regulator.
birddog321
Buford, GA
10-4 getting off work soon so Ihope to have results by this evening
birddog321
Buford, GA
Pulled the fuel filter and Chocolate Milk poured out of the filter. Dropped the tank and there was a little debris in the tank but not much. The sock on the pump has debris in it, is this normal? Should I change the pump? I am taking the injectors out tonight and let them soak for a couple days and hope for the best on those.
