Not Another CTOR Build
McCormick
What size tires are those, and do you have a close up pic of the track bar mount? Looks real good, I have a '77 44 waiting to go in my bronco soon.
chico4554
CT
man that thing is sweet. Great job. I love FW B dueces.
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
yeah that would be lack of gears lol...........
tires are 15x10 with 36x13.50 iroks
the trac bar mount isn't done yet still working on it
I def need softer coils
badblue
Orlando FL
nice rear flex butare the frount the TTB coils ?
94STXRanger
Kansas City
Thats beautiful man. I agreed with the name popeye if you havent got one yet. That last pictures just defines the one-eyed muscle man.
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
i got my 4.88R gears and install kit today, just waiting on my carrier and they will be installed, and i'll have 4WHEEL DRIVE
fordwheelinman
I still think it should be called popeye
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
installed my gears and welded the spiders, also i purchased some 5.5" Superflex EB coils from broncograveyard.com
Okay got my springs installed, their not broke in yet, but they are softer then my SJ's but not as soft as i would like. Maybe they'll get softer as they break in.
Got my front headlights and parking lights wired up. Also got my Winch hooked up and i'll have to make due with the shorter winch cable for now. Still need to make a few more braces to the frame/bumper to strengthen it. I still need to mount one shock in the rear and make a rear bumper. But its damn close.
I may have a hub going though, the LF is extremely hard to switch from free to lock and back to free
And my Radiator has a pin hole leak somehwere on the pass tank about half way up, so thats another thorn in my side i gotta fix
Jspafford
Logan Andrew Feb 17, 2012
Canal Winchester, Ohio
Man, that is awesome to see it go from two different trucks to one. Makes me want to go out and rip my b2 off the frame and rebuild it.
Thanks a lot....
Looks great!
Not All There
CT
wow that has changed alot since the last time i was one here, nice work.
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
heres a pic of the bumper i am putting together for the rear
fordwheelinman
Is there any other way....i think not.
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
yes that is weld
okay, got my last shock mounted, and the rear bumper done, also put my plate on it and changed the spark plugs
really all that is left is a radiator (its leaking between the tank and the cores) and finish supporting the front bumper
heres the rear bumper mounted (it looks really wide, but my tires are still wider then the bumper)
amd i had my first mishap...........
i popped the coil out (LF) when i lifted the front tires off the ground, the eyelet i put on to retian the bucket bent outward and released the coil (i replaced it with another eyelet and welded it closed so it cannot pull apart again)
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
soon 5.8L
i haven't decided, but i will probably do an interior cage eventually
