plastic inner fenders
chrwilkins30
Mishawaka, Indiana
how easy are they to remove. i cut my before and plan to lift it and want to put regular ones back on. so water cannot access the passenger department between the door.
The Jester Race
ΜΟΛΩΝ ΛΑΒ&
Sacramento, Kalifornia
Ford, BMW
They are a mother ****er to remove undamaged. I'm in California and my truck is a California truck (read: no rust) and all the screws were rusted solid. And if you try to grind the heads off you just end up melting the plastic inner fender.
Good luck
-Jester
H311RzR
U.S. Military - Active
2.8L
I actually had no problem removing mine...both came out intact....some of the bolts were tuff but some penetrating lube and elbow grease and they came right out.
4.0B2
Walls, MS
4.0 v6
the screws were a pain.. but i just cut the heads off the screws and went for it. wasn't hard at all.. but it is a lot easier to pull the tire out of the way! lol..
start soaking screws now if possible and spray them a couple times a day for a few days if you can.
Bennybooster
EMT / Paramedic
Medford, Oregon.
wow.....it sucks for you guys......mine were easy all of the bolts came right out, however my fender flare bolts were a PITA
4.0B2
Walls, MS
4.0 v6
fender flare bolts?? what's that? lol..
idk why mine were so hard to spin. so i just cut them off. actually only 2 were hard to spin b/c after that i started cutting.
