posting for my buddy
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
so my friend bought a 92 ford exploder 2dr, with a auto.
it has a new rad,thermostat,fan clutch,hoses. when he drives it is gets hot and boils out of the return tank only. i mean it acts like you pop the cap on the rad. it doesnt over flow out of anywere else.
any ideas on what could cause this?
rickster
Northville, MI
3.0L
I believe there are two radiator caps; one on the radiator and one on the reservior. Try replacing the cap on the radiator. If a radiator cap fails to hold pressure it will allow the coolant to boil over.
mjonesjr
I dance with the Devil...
Firefighter
Salem, IN
2 radiator caps? Where did you get this from? The reservoir cap is nothing but something to keep dirt out of the overflow tank.
I agree, it sounds like a head gasket. However, it could also be a water pump.
East-Central Pennsylvania
1987... sorta
'93 4.0
Typically if a water pump isn't leaking it isn't the problem.
(Think horses not Zebras)
Though I've seen atleast one Cologne water pump that had the
vanes corroded off the impeller... (Zebra, not a horse)
You can buy chemical test strips that you can dip into the engine coolant
that react to the presence of combustion products in the coolant.
That is an absolute indication of a problem.
BTW, when you said "New Rad" was it really a NEW rad or a "Junkyard new"
(New to the vehicle) radiator?
AD
IlovemybroncII
greenville sc
198
Chev
For
Test strips dont always work
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
did a water pump on it and it still over heats, going to try a rad cap. if not that head gasket? theres no coolent in the oil
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
Do you know that for sure? Have you had an oil analysis done on it?
no i didnt, but theres no milky white, nothing was wrong with the fluid when we changed it. when its just warm and you take the cap off the retrun res over flows. tighten the cap and it stays fine
Cheaplabor
MT
Are you sure the thermostat was installed correctly and works, my buddy had a car doing the same thing would over flow out the reservoir. After going over everything found out the ''mechanic'' he took the car too never put a thermostat in at all:annoyed:, after we fixed that it ran like a champ.
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
yes it was done right, i installed it and everything. tryed a new rad cap and its still doing it but no quite as bad
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
well my buddy has given up and has takein it in to the shop.....now if i can just talk him into joining up on here :D
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
well he got it back today. his fan clutch was bad
