seeking 2.9l to 4.0 4x4 manual swap help and electrical guidance
TexCaliBII
Yuba City, California
Sorry,
Been working on mine this past week when I had time, been in an exercise this past week too. 12 hours/day takes it's toll on you. Turns out the only EVTMs I don't have are the 89 BII and 91 Ex. Any others I've got you covered. As for the Ranger harness swap into a BII you will lose the ability for rear defrost/wiper, if you have them. The Ex harness should plug into your 89 but there will most likely be differences in pinouts. Also, the EX harness does not have the wiring for the rail mounted fuel pump so you have to splice there and the others shown in that write-up. You're right that the engine swap is the "easy" part but for the most part the woiring isn't bad as they are simalr vehicles. Also, on the subject of headers. Yes, you can use Ex header but the frame rails are not the same deminsions and you'll have to cut and/or notch the frame on the BII's passenger side. I have that next on the list for my 88/4.0BII project, right after the 8.8 axle I'm reading to go in, the man exfer case swap in, head gaskets, etc, etc.
BabyBronco89
GR Michigan
95' 4.0 OHV
okay so today is the day i will be ripping into the B2!!!!!!
The 4.0 is my christmas present, lets hope its not a late one!!
Going to the inlaws for dinner/presents, then when i get back home the 2.9l is coming out!!!!!!
im planning on keeping my auto computer as i scoured both the LKQ pick a part yards around the greater grand rapids area and i couldnt find one manual 4.0 vehicle in both lots, i was pretty bummed.
so i need some questions answerd
What Sensors am i going to have to disable or short/cross on the auto trans part of my harness to disable the park/shift selector..
i currently have the clutch saftey switch on my b2 stuck open with a golf pencil so my clutch dosent need to be pushed in to start.
what other problems am i going to run into useing a auto computer on a manual trans?
ALSO still looking for 91 Explorer 4.0 auto trans 4x4 EVTM
ALSO LOOKING FOR 89 Bronco II 2.9 man trans 4x4 EVTM
Btw idc if your answers are 100% correct but a lil help is great help n will most likely help me figure out the problem
will keep everyone updated and the computer will be right next to me during the swap.
thanks for your help
BabyBronco89
GR Michigan
95' 4.0 OHV
also are the wiring colors going to be the same on the 89 B2 and The 91 Ex?
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
You can use my write-up for the 89 B2 side. Wiring on the Ex side shouldn't be too hard to figure out.
And you can use an auto ecu, just bypass the neutral safety switch.
BabyBronco89
GR Michigan
95' 4.0 OHV
Sweet can u scan me the engine bay electrical diagrams or send a couple hi-def pics?
that would be awesome!!!
I just got the 2.9l out of the engine bay, boy is that thing a greasy mess!!!!!
Itll be a month or too before i wear that off lol
so tom after all the christmas festivities hopefully around 6pm ill be back to Working on the BII
First priority is to clean up the engine bay a bit then start compareing harnesses when im starting to feel comfortable with how the wiring will be ran ill drop the 4.0 in and start making my new harness.
OKay so for the guys that have done this What/where is going to be a good place to start my wiring Adventure?
i also took a lot of pics today of what i got accomplished too tired to upload them now but will tom for sure
Merry Christmas To Everyone At TRS!!!!!!
country0001
Stillwater, OK
Ford,Ford
The wiring isnt that bad. Just start taking it out atarting at the computer and work around.
On mine the only place we spliced was at theback towards the taillights.
My donor was a 94 2wd Ranger.
My problems came w pw and the elec 4wd. No biggie. I switched to manual doors and tcase.
BabyBronco89
GR Michigan
95' 4.0 OHV
First day ripping into the B2 Lots of Pics
Okay here is the last picture of the 2.9 untouched in the engine bay
heres the 4.0 once agin with the harness in a rats nest on top of it
Getting the 2.9 all unhooked just about ready to pull her from her old home
BTW IF ANYBODYS LOOKING FOR 2.9L Stuff My ENGINE IS UP FOR ADOPTION SOME SLIGHT PROBLEMS BUT It was running strongish before i pulled it out
all new gaskets less then 3 months ago entire engine was cleaned out all the grunge from the oil panect and new oil pump n new head gaskets
Gotta have a little heater in the cold here in michigan, we might not have snow yet but it gets a little chilly. this little heater does enough just to keep the nipp down, also im doing all of this in my garage that comes free with my aptment, not supposed to work on cars here but IM a REBEL
Here is where i cut my 2.9l fuel lines
still figuring how ill connect the two
this is how greasy my engine bay is although im not complaining at least i know my frame will never rust :D
partly from haveing a leaky clutch slave and a powersteering hose i waited months to get fixed along with valve covers leaking before the new gaskets
theres no going back now!!!!!
the old 2.9 has left the building
shows a little better exactly how much space im working with a little tight but im manageing at least im out of the wind and cold.
found out i got some rot on my radiator support, its still decently strong but it wouldnt hurt to replace it when the time and money is right.
truck spent is first ten years down in texas but these last ten years in michigan have been rough on her
Heres a better pic of my 2.9 if anyones interested not looking to get to much out of it so if anyones looking let me know
2.9 clutch basket
2.9l flywheel
not a bad lil motor but its on to bigger n better things now
theres the 4.0 not as pretty yet but def bigger :D
OKAY heres the wiring parts that ive came across so far
this plug not sure what it acctually goes to but this part is coming out of my B2 head light harness near the battery it has three wires going to the plug
there is the same plug coming out of the 4.0 harness from the ecm that wants to connect to it but this one has 4 wires, all the same colors just a extra wire with the 4.0
this is the b2 head light harness female side (3 wires)
this is the male side coming from the 4.o harness ecm plug (4 wires)
hoping i could make my first connection between the EX and B2 i tried plugging them together and this was preventing me
so there is my first electrical road block
Okay so i have the 4.0 ecm plug ran through the firewall and the engine control relays attached to the firewall i also have the mass of the harness that runs along the top back of engine bay sort of in place
here is where the 4.0 harness im guessing will tie in with the B2 headlight harness or the trans harness IDK IM getting closer to the SCAREY PART
this is where my spliceing will begin or wires will be rerouted? near the big white plug on drivers side,,, this is 4.0 harness
okay this is the EX Big white plug, it starts from fuse box runs behind headlights behind overflow/winshield resovior and ties back into the BIgwhite plug and the EX harness that runs over the back of the engine bay and i think connects into the plugs i previously metioned that i would have to splice for engine controls or trans switches
Im guessing i will be getting rid of most of this as everyone says i will use the B2 headlight harness
but what will i have to pull out of that mess? brake fliud resivoir switch?? windsheild wipers? oil pressure? water temp??
or will i use all of my existing connections from the B2???
Heres my garage as i left it tonight not too much space but as you can see im really diggin in at it
okay heres my fuse box on the b2 side and my ignition wire that goes to starter solinoid, im pretty sure im keeping this for the 4.0 correct me if im wrong. also the 2.9 alternator harness where it meets the box.
so i use all the alt wires from the B2 just splice the 4.0 alt wires to these here?
then start spliceing all the circuts from the b2 fuse box to the explorer fuse box like fuel pump, ecm, headlight, power windows, ect????
also it seems like i found a plug under my b2 dash that seems to wire what looks like heater wireing(not for certain) but it hooked to my 2.9 harness near ecm plug.
the big plug with about 8 wires on it on the right corner starts somewhere up in my dash and connects to the other gray plug on the left then leaves the cab next to the ecm rubber socket and plugs into my heater blower motor....
where the question arises is i see the same plug coming from the fuse box on the 4.0 harness and dosent run to my dash???
also there is a pink wrapped wire that plugged in by the ecm on the explorer and i dont know where or if it will go anywhere on my B2..
so basically if you know what any of these connections is please help me out, i am clueless untill i get these evtms or a RBV GURU magically shows up at my garage
sorry if i am rambleing or if something doesnt make sense please feel free to ask any questions or provide any bit of info it will Be greatly appreciated
now i shall go to sleep well 2.9ls and 4.0ls dance in my head and the colors and plug shapes begin to haunt me.
I HOPE EVERYONE AT TRS HAD A WONDERFUL CHRISTMAS!!!
country0001
Stillwater, OK
Ford,Ford
The one by your headlights is your power windows.
I used the ranger harness on my headlights. I just spliced at the taillights.
BabyBronco89
GR Michigan
95' 4.0 OHV
Okay thanks for that bit of info any idea as to why there is a extra wire on the ex side? Maybe a extra ground is all I can think of:?
BabyBronco89
GR Michigan
95' 4.0 OHV
What year ranger did your donor come from? Okay I'm guessing the taillight harness is the one that runs along the frame rail on the drivers side underneath the brake booster ?? So you used the big white plug from the ranger? And plugged it right into the female end of the b2 harness? Or did your splicing there?
country0001
Stillwater, OK
Ford,Ford
I used a 3rd gen Ranger. It plugged right in. The taillights were different plugs but the headlights worked. You have an advantage using the ex. I wouldnt think there would be any splicing at all. It all plugged in for me. But I also switched to manual doors ans tcase
country0001
Stillwater, OK
Ford,Ford
Not sure on the extra wire. Just remember. The b2 is just the first draft of the ex. It has the same engine compartment w the same holes. It will all go right in. Ford doesnt like change.
BabyBronco89
GR Michigan
95' 4.0 OHV
Protowrxs
Shawnee,OK
2.9 - 4.0 Waiting
okay so got it all wired up according to the official 91 explorer to B2 swap
http://www.therangerstation.com/tech_library/4-Liter_Conversion_wiring.html
acctually wasnt that bad :D
but when i turn my key i cant hear fuel pump turn on?????
im retraceing my connections now.
shes cranking over and acts like she wants to go but without gas shell never fire!!!
The computer turns on the fuel pump via Tan/LG wire. That wire is on the test connector as well. If you ground the Tan/LG wire at the test conn does the pump run? If so then the computer is not getting info to turn the pumps on, i.e. it doesn't know you're trying to run/start/etc. If not then the fuel pump relay doesn't have power or the inertia switch is open or something.
That assumes the computer relay is working and powering up the computer when you go to run/start. That is usually a R/LG wire coming from the ignition in run/start position that turns on the computer power relay.
Just thinking out loud...
-Stephen
BabyBronco89
GR Michigan
95' 4.0 OHV
okay now i have a fuel pump but no spark still cranking great
:dunno:
BabyBronco89
GR Michigan
95' 4.0 OHV
okay also forgot to mention my o2 sensor isnt hooked up they were different plugs and i didnt think to check before the eng went in...
this woundnt make me have no spark?
the fuel pump relay kicked on after a lil knocking around by the fuse box
this is really starting to itch me
why cant i get SPARK???
which wires are nessasary to make engine run?
ive checked all my grounds and im going over them again
BabyBronco89
GR Michigan
95' 4.0 OHV
okay so i think the comp was a little confused i reset comp by disconecting positive and gound for a few mins then i had spark and fuel pump but i still cant get her to fire,
:dunno:
BabyBronco89
GR Michigan
95' 4.0 OHV
So the beast lives!!! N it breaths Fire!!!
Must say it was def worth it!!!!
4.0 is amazing!!!
Will have more build thread n pics n hopefully some video too
Thanks for everyone's help couldn't of done it without TRS!!
