tanny question
You can bolt it to whatever you want. Still needs a computer to tell it to do things. A 2.9 computer will NOT work a 4R70.
tsi617
However I shouldn't of chimed in this I guess since it's a 2.9. For some reason I thought I was in the 5.0.
I'm an ass, and I can admit it.
Sent from my XT1080 using Tapatalk
How do i tell if i have the A4LD transmission? Its A 1990 bronco ii Eddie Bauer Edition 2.9L automatic transmission if that helps.
However I shouldn't have chimed in this I guess since it's a 2.9. For some reason I thought I was in the 5.0.
Just gotta read all the words man.
tsi617
True. You'll have to get a external tranny controller for any mechanical to electronic swap. There are plenty out there and run in the 4-600 range.
Yeah, but if you are going to go with a stand-alone controller I'd try to get a 5R55. Easier swap.
tsi617
Depends on which motor is driving it and what you are planning to use it for as well as power goals.
treel98
NorthWest Indiana
2.9 for now
Ok I am confused what does all this mean? What should i do? I am only 15 and all this about the c5 and c4 and manual transmission or computer transmission is like teaching a 2 year old calculus.
PetesPonies
east coast
The A4LD is the obviously trans even for the 4.0 in your situation. It is inherently a weak transmission. But if it is working fine, just go with it. Change the fluid often and don't overheat it. If you want to change transmissions, you could use a C4 or a C5 as long as you get a bellhousing from an 83-85 2.8 C5 transmission. That bellhousing will allow a C4 transmission or another C5 transmission bolt up to your engine, either 2.9 or 4.0. Got it?
