if the connection is good, i'll test the starter tomorrow. but it seems strange that that happened right after i messed with the fuel pump. and can anybody explain why the pump wouldn't turn off after i unplugged it and plugged it back up?
whenn u turn the key on the pump energizes or builds up pressure in the fuel line
once the pump hits the right pressusre it stops buzzing also underneath the carpet passenger side tranny area is the inertia switch unplug it and put a jumper to connect the two wires bypassing the inertia switch taht switch can cause alot of problems
but dont leave it that way it is dangerous cause if u get hit that shuts off the pumps
and check ur o2 good luck
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
