8H rebuild
CopyKat
Manitoba, Coldest place in Canada
Rebuilt the M5OD in the Bronco Saturday. Took me under 8H from rolling it into the shop to driving it out. Remember this is Just me doing the work. I had no help.
replaced the bearings and syncros.
Would have taken me less time but I also rebuilt the cardian on the rear driveshaft.
BlackBII
Cheaf of Grammor Poleace
Orem UT
Good for you! Want a gold star? :icon_twisted: HaHa!
That's pretty good, but I have you beat. Two weekends ago I pulled my M5OD, went back to the junkyard and traded for a new one, put it back in. All in ~3 hours.
(I'm not one to rebuild tranny's, I haven't the tools to do so.)
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
i didnt think there was any special tools required to rebuild a tranny:icon_confused: i have to take a 2.3 m5od and 4.0 m5od swap the 4.0 guts and tail shaft to the 2.3 case so i can finish my truggy....
i rebuilt a t5 outta a 80 stang, i made it into a world class t5 and it took me 4.5 hours :D it shifted great and i sold it to a guy for 1K:icon_hornsup:
CopyKat
My Junk yard is 45 min one way. And it's in about 2 feet of snow. No way i could swap one out in 3 H. But if I had the trans ready to go it wouldn't have taken me near as long to do. Rebuilding is cake. There is only one special tool you need but then you really don't need it if you have a cresent wrench big enough. I took my time and made sure everything was good, inspecting nearly all the parts.
The driveshaft was what gave me the most grief. Both taking it off and rebuilding the cardian.
Good thing I have a suspension lift as I needed no jack stands, and thanks I have a 1.25" bodylift as it made getting the top bellhousing bolts a breeze.
country0001
Stillwater, OK
Ford,Ford
Hell it took me 6 hours to get mine out the 1st time. That was just a clutch change. I'll be faster next time.
PlumCrazy
Pataskala, OH
Dont put the 4.0 guts in the 2.3 case, just swap tail shafts and housings. Unless you want to gear UP. the 2.3 gears are lower in 1,2,and 3.
CopyKat
Sasquatch_Ryda
Coast Mountain Crawlers
Terrace, BC, Canada
4.0L/4.0L/6.4L
Hero Cookie!
trail B2
North Eastern Ca.
The bell housing is different between the 2.3 and the 4.0/2.9 aren't they?
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
so i just put the 4.0 tail shaft on the 2.3 trans?:icon_confused:
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
that was my understanding. i have a 2.3 in my truggy and its a 2wd. i need 4wd so i yanked a exploder 5speed and was told to swap the guts and tail shaft so i can have 4wd
PlumCrazy
Pataskala, OH
Yes the bell housings are different.
He wants a 4x4 2.3 trans, so he just needs to swap the tail shaft and tail shaft housing from the 4.0 onto the 2.3 trans.
PlumCrazy
Pataskala, OH
CopyKat, Do you remember what size the nut is on the output shaft? I borrowed huge crows foot from my uncle last time, but I like your design. I think I may steal your idea for my next hybrid swap.
I would measure the extra one I have laying at home, but I am 2hrs away and I may be able to talk my professor into making one for me on a CNC Laser he has where he works.
IlovemybroncII
greenville sc
198
Chev
For
copykat a smart thing would be go to jy and buy one this summer rebuild it and have it as spare then when you need rebuild again pop it out slam the spare in the in with siting by wood stove rebuild the it again recycle it
PaleBlue90
Aurora Colorado
2.3,2.9 and 4.0
This is all you need to do.:icon_thumby:
sweet thank you both:icon_thumby:
i could have someone make one for me too if he posts the size of the nut. thats a really good idea to make that tool:beer:
CopyKat
It's big! :dunno:
No need right now. I have 3 in my shed. Just the $300 for the rebuild kit is costly.
