I'm putting some 36/12.50/15 swampers on my bronco 2. Will the stock axles hold up to that big a tire? How long will the stock axles last before they break if they won't hold up?
No, the D28 almost doesn't even hold up with the dinky stock tires, let alone 36s (I wouldn't really trust the 7.5 with over 33s under a BII either).
To run those tires your easiest swap would be to the D35 & 8.8" from an Explorer. Very common swap, info on it is throughout the forum as well as in the Tech Library.
