B2 on the Rubicon Trail!
higgins lake mi
BIGGER
:shok: that link is crazy.
i guess i can step back and laugh pretty fawking hard.:icon_rofl:
i run a, full travel, maximum compression to maximum extension, of spring that was rated 140 ppi, and 5.5 lift with pivots over center, at up to 120 mph on the pavement, for three years...... with simple junkyard steering parts......and incoil bags...
and somehow missed most of that shit.
:icon_rofl::icon_rofl::icon_rofl::icon_rofl::icon_rofl:
jkufen
Charleston, SC
Where are you that you can't find one example of what was America's best-selling SUV and compact pickup truck around you? You try www.car-part.com? How about www.craigslist.com?
I have not tried car-part.com but craigslist is my go to site. There are plenty of explorers here but the owners are wanting $1500+ for them. One here is a 92 explorer 4x4 and the guy wants $1700 for it. 235,000 miles, no a/c or heat, and the head gasket is blown! Not to mention the other issues he had listed. I mean it's ridiculous. I would like to buy something like that but I'm not made of money I have to keep my parts budget down so when the modifications come in I'll have the money to do it right. I'll have to search some pick and pulls and see if I can find anything reasonable. I'll try that other site.
higgins lake mi
BIGGER
theres a few times i nearly sent shawn a ticket so he could go junkyarding with me for a few days.
that would completely change his outlook on this based on geography.
the reality is so brutal, and painfully ugly he would go home and hug, kiss, and fawk hiis d35 to death....... :thefinger:
probably 2 to one or better d 35 to 30.....but the 35's are in such sorry shape you just feel bad for the lil fawkers. 3 to 1 sla to d30....
jkufen
Charleston, SC
I am sure I could easily do the 3-4 link system because my buddies are familiar with the link system because they run low riders and hydraulics and they have that on their trucks. I am sure the links systems are the same for low riders and 4x4s so that won't be a big issue. I don't think.
jkufen
Charleston, SC
Yeah the few I have seen over the years here were not in good shape. They were rusted to hell and I was scared it was worse than just surface rust so I moved on. Hopefully I'll find a decent straight axle d44.
jkufen
Charleston, SC
Ok well I have a pretty good idea how to do a d44 swap into my b2 now. I have found the radius arm setups from James Duff but its like $600. I also found the shock tower and the coil spring buckets for $300. Any idea if they sell them any where else cheaper?
4.0B2
Walls, MS
4.0 v6
Fab them.
JD sells everything you need for a SAS I think lol
jkufen
Charleston, SC
could I fab the radius arms that are on my b2 now or will that be too much modification? I am not sure how much bigger the d44 radius arms are.
jkufen
Charleston, SC
What axles would come in the f-150? There are a few f-150's for sell locally for less than $1000 and that is my price range.
jkufen
Charleston, SC
Ok so far I have called around to a few of the pick and pulls placing and I have found the front end of a f-150 for about $200 with everything. The rear end is about $150 and a transfer case is about $150. So all in all $500 will get me all the big parts I need for my build. I will just take my time and replace everything in the axle and upgrade the shafts etc and the same for the t-case and the rear end.
Another question I have is on the Pirate 4x4 site I posted there as well just to get a range of tips and advice. Well one of the members said I should get rid of the fm145 transmission. I was planning on rebuilding the fm145 and keeping it. Is it worth keeping or should I swap it out for another trans? If it's best to swap it out what would I replace it with?
4x4junkie
Mall-Rated
So. Calif (SFV)
Didn't answer the question...
The FM145 is OK at best. I would swap it for a M5OD instead of rebuilding the FM145, but would run the 145 at least until it comes down with an issue (unless you were to do a 4.0L swap, then the 145 is likely to be a very short-timer).
jkufen
Charleston, SC
What can I get a m50d out of? I'm sure another b2 or ranger but any specific years?
4x4junkie
Mall-Rated
So. Calif (SFV)
'90-'97 4WD 4.0L Rangers & Explorers.
'90 2.9L 4WD Rangers & BIIs (though M5ODs are more rare in these)
You're not gonna tell us the city you're located in? (or maybe put it in your profile info)
pimtool
OTOTM Winner
prosperity,SC
Wow, I just read that whole thing and you are thinking way to much into this. If it were me I would go with d35, 8.8, 5.13 gears, 35" tires, lockers front and rear add some skid plates and rock sliders and peoples jaw will drop as you climb almost anything at Gulches and have it all done in a month.
Just keep some extra hubs and front axle shaft on board and as someone stated earlier you can swap them out in 1/2 hr or less.
By the way where in SC are you?
jkufen
Charleston, SC
sorry guys for the late response I am in Charleston, SC
jkufen
Charleston, SC
Ok Ill check around at some of the local pick and pulls and see if I can find the m50d trans. I am assuming the 4.0 rangers between 90-97 also have the d35 front end too?
pimtool
OTOTM Winner
prosperity,SC
Hey, I have a 89 I picked up a month ago not running for $750. I put a fuel pump in it and changed the oil. Its a little rough around the edges, but I ran it around the back 40 a couple times.
$900 just above Columbia,SC
jkufen
Charleston, SC
and that has the d35 and 8.8 rear??
pimtool
OTOTM Winner
prosperity,SC
Nope. I thought i would have time to do that, but I was wrong. Just thought you could build it while you continued to drive yours.
