This, except use a pry bar to move the wheel straight up and down. It's easier to find ball joint play that way. Rocking it by hand can throw bearing or tie rod play into what you feel and give a false positive.Lift the wheel off the ground, shake it from side to sid, then up and down. If there is any movement or if you can feel/hear any poping then something is broken. Could be a ball joint, tie rod end, or wheel bearing.
If you do feel that loosness then go behind the wheel while someone else shakes it and look for the source of the movment.
Usually I can see a bad ball joint just by looking at how the knuckle moves relative to the beam. Ball joint or wheel bearing play are both pretty easy to see and distinguish from each other. Any more than 1/32" play in ball joints equals worn out anyway :icon_thumby:This, except use a pry bar to move the wheel straight up and down. It's easier to find ball joint play that way. Rocking it by hand can throw bearing or tie rod play into what you feel and give a false positive.
moog ball joints cost me 65 each , I would also do the inner u joints at the knuckle at the same time.
I spent about 300 on parts when I rebuilt mine , that included bearings , seals , the afore mentioned u-joints , ball joints, brake pads, break hoses
A shop will charge you that much in labor easily, just for one side.
