koomz
- Jan 31, 2009
- 28
- abbotsford
- 1986
- Bronco2
- 2.9L v-6
so over the weekend i plunked in a d35 out of a 92 exploder into my 86 b2..which has a 4" trailmaster lift.
and during the week im gonna to 8.8 rear...i know about having to weld on new perches....but heres my questions..
#1-how do i know how much to have my front drive shaft shortned and do i need a front explorer drive shaft end(u-jont) or does the b2 end(u-joint) work
#2-for the rear same question..change the drive shaft end to the diff..? and do i need to shorten it.?
#3-my camber is crazy off..is there enough play in the diff to correct this at the 12point camber bolt and the 1 1/8 bolt on top..?or are shims required.
#4-true or false--explorer leafs wont sag..? when intertwined with b2 leafs. and some lift is gained..?
#5-true or false a explorer 10" flywheel and starter will bolt into a 2.9L standard tranny and block...and whats the benifit ...?
any help will be great thanks..
