Liftgate mod
johnsongang
San Antonio
I'm in the middle of repairing the damaged fiberglass on my 90 B2 with the spare tire carrier. I want to continue using the tire carrier so has anyone had any success beefing up that area with some steel or other material? If anyone has links or pics, that would be great!
country0001
Stillwater, OK
Ford,Ford
I reinforced mine with a pieceof 4x6 1/8inch steel. Drilled all the way thru the door. Held up pretty good
birddog321
Buford, GA
Diamond Plate. Tough, and it looks good on anything
johnsongang
San Antonio
Do you have any pics of the steel reinforced liftgate? I scrolled through your rebuild posts and didn't see that part. Thanks...what part of the door did you attach the steel to? I'm thinking of a way to attach it to the steel frame part of the gate, so there's not the stress on the fiberglass from the spare tire bouncing all the time:icon_thumby::icon_thumby:
5.0fox
Carbonado, WA
I run. Waterjet for a living and cut myself out a couple titanium sandwich plates to reinforce the area around the latch. I've been running it like that for 6 months with a 33 inch spare and it has held up great. I have some spares cut out if your interested in a set
country0001
Stillwater, OK
Ford,Ford
I''ll post some pics this weekend. Aint no biggie, just put some steel over the crack.
I actually like the sandwich idea!
5.0fox
Carbonado, WA
They turned out pretty nice. I busted out about 10 sets. They use the original mounting bolts and holes as well as 10 quarter inch bolts around the perimeter. If anyone is interested in a set shoot me a pm.
country0001
Stillwater, OK
Ford,Ford
Pics and prices please. I might be interestedjust to have another set and protect my good hatch.
country0001
Stillwater, OK
Ford,Ford
This cost me a dollar for the metal, 20 cents for the nuts and bolts.
Sandwiching would probably be better,but this has held up
5.0fox
Carbonado, WA
50 bucks shipped will get u a pair of plates. I can't post pics from my phone but ill send u some pics if you pm me your cell number.
4.0B2
Walls, MS
4.0 v6
pm sent. i'll post the pics up for you.
4.0B2
Walls, MS
4.0 v6
pics from 5.0fox
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
There are 2 different styles too as you can see from country's pic and the one 4.0 posted. If you have the 2 bolt one, I'd find a 3 bolt one. Thats what I have and haven't had any problems keeping a 35" spare on it.
johnsongang
San Antonio
You mean you reinforced the outside and inside "sandwhich style" what size and thickness are the plates you used..yes I'm interested!!
TexCaliBII
Yuba City, California
I never like the look of a reinforcement panel on the outside of the hatch. So when I repaired my 87's hatch I made one to bond to the inside, cut and fit to match all the contours and mounting holes. I have been running my spare now for years with no more cracks. I did not take pics when I originally did this but I will be doing this same repair to my "new" hatch on my 88 so I will take detailed pics so you can see what I am talking about. I've done this to 2 BIIs now and both are rock solid.
