alignment and snow run
so the alignment was pretty good. spent about a hour to get it almost 0 toe in and then more work to make it so that the steering wheel was straight down.
except after all that work it looks like the rear end is cocked a little bit. so it still pulls a little bit to the right
It runs easier down the road - I can coast longer than I used to. so I am close. Need to work a little bit more on the rear axle to see if I can get it straight.
did another snow run today. REALLY REALLY sucky snow. crust on top and then dry powder sugar snow underneath. As long as you were on top of the snow you were ok. break through and then it was shovel time. :icon_twisted::sad:
Even our most capable rig was breaking through the crust and having to winch constantly.
As we were airing down a guy asked us how far we were going in. Turned out he had stuck his stock 4 runner about 4 miles in the previous night. So gave him a ride in. He was pretty stuck and had broken a front hub also. We tugged him out and got him on his way.
We had to get around him first as the track was real narrow. As I was going around i got sucked into the powder. So I did my first winch out with the new bumper. With all the guys razzing me :icon_thumby:
No issues. might pull off the rear bumper and reweld that while I am thinking about it.
When we came out and were airing up, I had a minor issue. I unintentionally did the one thing that you cant do with the MV50 air pump. turn it off to check air pressure and then turn it back on. the pressure from the tire goes against the piston and the motor cant over power the pressure.
blew the fuse and then blew my spare when I forgot to pull the leads from the battery. guy behind me finished airing up my tires so I was ok.
also compared my normal air gauge with my new slime air gauge. turns out my good -$7 Milton - air guage is about 3 lbs high compared to my other gauge. checked it against my buddy's gauge and the Slime one was same as my buddies.
So that means that I was running at 11 psi instead of 8. I need to take a picture of how much the x-terrians bulge out - it is incredible
