my B2
86 slo-vo
02/2011 OTOTM Winner
owensboro, KY
yea ive seen those switches...let me know how it works
wonder what kind of amperage it will hold
NMB2
July 2010 OTOTM Winner
Ft. Lewis, WA
5.0 V8
not sure on any amp draw specs. We'll see how it works out. Its a pretty trick little peice if it holds up.
chazzone
Camby, IN
Use a good relay for each circuit, and it shouldn't have to deal with too much voltage.
NMB2
Ft. Lewis, WA
5.0 V8
got new bulbs for em.
100watt 5900k
NMB2
Ft. Lewis, WA
5.0 V8
slammer67
Salida, Colorado
ranger
that truck is awesome.
You said you had trail gear springs, so I'm assuming there toyotas, but what lift?
are they the HD springs?
I was looking at tg springs also
slammer67
Salida, Colorado
ranger
so you went full hydro with a single ended ram?
hows the steering response, Is it slower than a double ended ram?
NMB2
Ft. Lewis, WA
5.0 V8
technically its slower/weaker steering to the driver side. Not noticable though... it will still push the truck off of anything single handed on the wheel.
NMB2
Ft. Lewis, WA
5.0 V8
cut the old thread insert that was messed up out... and put in a new one.
and one of the old Heim joints that I replaced on the ram
Put on some 4" TruckLite Aux. lights
Saddle Gussets
86 slo-vo
owensboro, KY
looking good man deffinantly coming along...need to cut those doors down to size
NMB2
Ft. Lewis, WA
5.0 V8
the plan will eventually be to take doors off and have a tube coming from the rear of the cage, through the doorjam and down into the lower spreader, then chop the rocker out and boatside it.
CHKNFKR
Illinois
545 CID
Im stumped...
I know I'm a few months behind here but what exactly happened here? did she pull out on you?
86 slo-vo
owensboro, KY
sounds like a pan..how much are you boat siding? just the rockers? or going higher?
Bray D
2012 UA Ranger
Manito, IL
Lookin good man. Actually, it looks pretty tight with the interior cage. Do you ever wish you exo'd it?
He's gotta go higher. If it just went to the rockers, they'd be considered sliders haha.
NMB2
Ft. Lewis, WA
5.0 V8
Weld cracked from the twisting force somehow. I welded it with like 3 passes and plug welded it the next time and I've got 3 runs on it without any issues.:icon_thumby:
the D-shaft was originally on this jeep and never broke... so thats why it was really weird that my truck broke it.
NMB2
Ft. Lewis, WA
5.0 V8
Nope, never wish I exo caged it. Too bulky, loss of clearances, I dont like the look of exo cages.
NMB2
Ft. Lewis, WA
5.0 V8
once the Door bar is in, Im going to chop the entire rocker from the front door jam, back. and some of the rear door pilar. the boatside will go from my flatbelly skid/frame rail, up, into my lower cage spreader.
86 slo-vo
owensboro, KY
yea thats what i was thinking lol...just wasnt sure how high you were planning, ive seen alot of the jeep guys go as high as 6-7 inches up the pillar
Bray D
2012 UA Ranger
Manito, IL
All are valid reasons.
I'm still up in the air about it. I ordered a bender, so I may get around to caging this thing this summer. If I do an interior cage, I'd like to go through my dash if possible. Single cab rangers are pretty small. Decisions decisions.
