- Aug 6, 2007
- 568
- Age
- 43
- Western Michigan
- 1975-1995 Ford
- FORD
- soon 5.8L
as soon as i can afford itI dont blame you. you going to get chromoly shafts?
The longer they are, the less binding (twist) you have in the axle C-bushings (remember the whole thing is trying to act like a big huge swaybar).no i am not, both arms are pretty much stock.
people are saying run ext arms etc....but my arms are already out to my tranny crossmember (i have the M5ORD) i really don't wanna run much longer arms. Honestly wouldn't going past the crossmember be a little much?
I have the FM146 in my BII (same length as the M5OD).
My rear driveshaft is somewhere around 27-28" flange-flange (that's with the rearend shoved back almost 3" though).
I have the M50D.
As for my rear shaft I am also using an Explorer front shaft shortened. As for length I don’t know it off hand and my rig is not at my place. I do plan on trailering it back today so I could measure it for you.
i'm at 31 inches, but i think with the height and angle my driveshaft is at that if i shorten it any it will bind, as it sits now i'm surprized it doesn't. I guess i'll have to lower it, i have been thinking of dropping it a little so i could loose the 4" block in the rear.
Pinion angle is maxed out (lines up with the driveshaft) and I do not want to turn it up anymore being i am already concerned with the pinion bearing and lube. And i am using a Frt explorer shaft with the double joint already.
I'll have to take a pic to show the angle.
Junkie and Todd, with your B2s what trans are you using? I think Todd you have the mitsu? and Junkie i'm not sure. I built a doubler for my old sport, but i broke the inner shaft and have put it all in a box in the corner of the garage. But now that i have built myself a B2 i am thinking of pulling the doubler back out. but i have some concerns. I am runing the M50RD trans and an 8.8. I am using a frt explorer driveshaft shortened an inch. Its pretty short. My concern is with the added 6"s or so of the extra doubler length my shaft just can't take being shorter anymore. What lengths are your driveshaft in the rear. I think i may just be to tall of susp lift.
Sorry stumpy for the small misdirection of your thread
