you would have to gut both trans and change the shaft, they are too different lengths, the 4x4 is shorter then the 2wd.hi i have a 99 explorer with a bad engine and i got a2000 explorer with 50k for the engine it is 4x4 could i use the trans if i have the tail shaft changed note i have the ecm as well ?
88 BroncoII 4X4 with A4LD and automatic transfer (push button 4wd). slips a little when engaging in first. Shifts really hard into second. Slips and stutters from second to third. Sometimes it won't shift and I have to put the gas down to get it to shift. Then it shifts really hard. Trans won't even shift into O/D, so I cruise at 60 running 3k rpm. Looking to swap in a Mitsu 146 5-speed or Mazda M5OD-R1. Any advice?
Too bad no one can find them.use the M5OD, it better.
Robert
If there are pieces of copper in the pan, then it's time for a tranny, there are copper bushings and copper washers in the tranny, you could try and change the filter, and fluid, but I don't think that will solve your problem.Hi guys, new member here.
I am trying to help out a woman that teaches with my wife. She has a 1992 Ranger 3.0 2wd auto. The truck was purchased new by her dad who gave it to her husband before he died. Then after her husband died, the truck was given to her daughter. What I'm saying here, is the truck is worth nothing to you or I, but to them it is priceless, and as such, it will get all the attention it needs.
The daughter drove it for a while but started having transmission issues and took it in for a service. 3 months later it would only reach a top speed of 25mph so she parked it, where it stayed for 6 months until I towed home last weekend. Before I towed it I checked the fluid level. It was full but it looked like engine oil that had done 20,000 miles and was horribly burnt smelling. I started it and managed to get it to drive up on the dolly but it needed a lot of revs and was making some dodgy rattling noises. I couldnt be sure it that noise was transmission/torque converter or exhaust heat shields or cat.
Tonight I pull off the pan and filter and it is disgusting in there. There is no way the fluid and filter in here was only driven for 3 months. This looks all original even down to the Ford stamped filter. (She didnt take it to a dealer for the tranny service) The magnet had about a 1/4 - 1/3 inch of thick black sludge on it and the rest of the pan had a 1/8 inch thick black coating on it. There were some tiny metal fragments and 3 pieces of what looked like a meatl ring. Think a piece of solid core wire in a loop. It was broken with one piece crushed flat. The filter was semi blocked with metal fragments, some copper colored. However, looking into the tranny, everything else I could see looked spotless with no metal fragments anywhere I could see. The dripping fluid even looked cleaner with a much better red color to it.
So at the moment I'm kind stuck in which way to go. I am tempted to put the new filter in and the pan back on and drive it to see if it drives better or to just tear it out now and rebuild it. If it isnt fixed, then I'm still only out $39 and about 60 minutes but I'll know whats what.
Looking briefly at the service manual the diagnosis points to it possibly being the torque converter. If I put it all back together I can do some diagnostics on it and narrow down the cause.
So what is the consensus here?
The local Pull-A-Parts in Knoxville, TN. only charges 80.00 with the 30 day warranty, if I had to pay 350.00 for one, it better have at least a one year warranty on it, and there is no way I would pay 650 for one.$80?!!!!
If I want one with 150,000 miles, I'll pay maybe $350 for it around here! I was looking at one with 68K on it for $650 last night.
where is "around here"?
Robert
posted from my laptop while playing with a iPhone 3g to see if it works.
Sorry, around here is Michigan. I found one for $150 this morning that had 212K on it and was not working. Umm, how about NO!
It sounds like its cheaper to buy down there and freight it up.
Couple of further questions:
How high does the truck need to be jacked up to wiggle this out?
Does the exhaust have to be removed?
Any gotchya's that dont look obvious before starting?
Does the engine need to be supported or will it rest on the mounts and stay put?
We took a work truck to Jiffy lube for a service and two days later the tranny went out. I'm not sure if these guys put the right fluids in. I will not take anything to them again. It was a newer truckWell, it's not a good sign when there is a specific portion of a forum dedicated exclusively to your transmission!
I have a 1992 Ranger four-wheel drive with a automatic transmission. Overall it very happy with this truck, but as of late the transmission has been giving me some problems, and you may have read about this in an earlier thread that I had posted.
Briefly, to summarize, I had the tranmission fluid changed by Jiffy Lube, and shortly thereafter when towing a small boat my transmission had spewed forth a fairly large quantity of red fluid.
My original assumption is that this was overflow fluid, as performed by the service center, and indeed the rate of discharge had decreased, but never ceased.
I had brought it into the mechanic for visual inspection, thinking that perhaps it was the overflow tube, or the dipstick tube but there was no obvious sign of the fluid leakage, except for between the bell housing in the engine block, an area such as would be disclosed by a failure of the front pressure seal.
I decided to watch and wait, and simply check the fluid level frequently.
However it continued to leak, especially under load.
Given the fact I don't have the time to pull transmission myself, I contemplated bringing it in, but that's a fairly expensive job on a fairly old truck.
Thus I decided to roll the dice and try some transmission sealer, which miraculouly appears to have worked. The prayer might have done the trick, as it were.
I realize that this is likely only temporary, but a least a limited time to save money for new transmission seal.
Hopes this helps somebody.
Bill
Would you trust a doctor who gets paid $7.25 an hour and has no education to perform surgery on you? Jiffy Lube type places are full of idiots that don't care. I would NEVER let them do any sort of work on my vehicles.We took a work truck to Jiffy lube for a service and two days later the tranny went out. I'm not sure if these guys put the right fluids in. I will not take anything to them again. It was a newer truck
