Sonnax Part Numbers are below. I got mine from wtttrans.com
U56680A Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 1 Groove).
U56680AA Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 2 Grooves).
U56680AB Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 3 Grooves) .
U56680B Governor, A4LD (Small Land On Valve Is .326OD) 1990-95 3.0L.
U56680C Governor, A4LD (Small Land On Valve Is .314OD) (Valve Has 1 Groove).
U56680CA Governor, A4LD (Small Land On Valve Is .314OD) (Valve Has No Groove).
D56681-1 Governor Body, A4LD (Small Land On Valve Is .314OD) 2.3L 1989-90.
S56681-4B Governor Weight, A4LD (35mm OD).
The items i bought were in bold. You should check your parts before you buy to make sure you're right.
