Gauges:
I decided to replace the instrument bulbs with LED bulbs. The old incandescent bulbs give off a yellow light. The gauges have blue bulb filters, but the yellow hue of the light make the gauges look green. The new bright white LED bulbs give the gauges their true blue color.
I also didn't like that the gauge needles looked sun bleached, so I decided to report them with some orange fluorescent paint that I got from Hobby Lobby.
Above you can see how white the needle is with just a hint of color at the needle point.
Below you can see how much better it looks after being painted.
Here they are lit up with the new LED bulbs.
If you remove the screws holding the clear plastic covers over the gauges you can then remove the metal trim ring. You can see where the portion of the needle that was behind the ring is still orange.
I used a brush to apply the paint and laid some masking paper behind the needles to make sure The brush didn't touch the gauge surface. It took about 3 coats to make sure the needles had good coverage.
