Project El Taco...1990 BII
master hec0
okotoks alberta canada
4.0L V6
i cant look at that 1st picture it messes with me. like that front end doesnt belong there yet its there and im scared.
RacinNdrummin
Auburn, Wa
This thing is going to look wicked with a lift and some bigger tires, I think the front end will grow into it when its bigger.
twoll86
U.S. Military - Active
idk about that grill lol its def different IDK WHAT TO THINK LOL
twoll86
after some photo shop
might make it look better idk
twoll86
could always make a kustom billit grill
cargs
3.0L
how is the B2 running? have you taken a video of driving around yet?
RacinNdrummin
Auburn, Wa
Runs great!
I took it down to Randle (2 hour drive) last weekend pulling my motorcycle trailer(~1500-2k lbs) and loaded with gear and camping stuff and it drove just like it does unloaded, feels like a V8 under the hood. Averaged about 18mpg. Unloaded freeway, it gets about 20-21mpg. When I have some fun with it though, it really guzzles.
I havent got video of it driving around yet, One of my cameras only takes 15 second clips, the other is cheap and doesnt record sound, and I cant find the charger to the good camera. Ill get my buddy to take some video with his camera next time we go out.
cargs
3.0L
Updates?
do you have pictures of what you removed from the SOHC engine to make it 'like' the OHV motor? i have a ton of hoses and tubes on mine that i would like to see disappear, just wondering what you did.
thanks.
RacinNdrummin
Auburn, Wa
Finished the heater box...and yes there is still air flow... Im working on a lift for it right now, Ill get an update on that when im done with pics. I picked up some 34" LTB's a couple weeks ago, I cant drive it til it has the lift on it though.
There will be some serious updates very soon, ive been working on collecting parts...
RacinNdrummin
Auburn, Wa
Update...
So I needed a little more lift than what the explorer springs were giving me to be able to drive with the LTB's on. I picked up some goodies to help with that:
3.5" Duff kit from another member on here and an SJ AAL for the explorer springs. A set of homebuilt extended RA's as well as a couple of 1" coil spacers will accompany the front lift, Ill get to that in another update.
I also built some HD extended shackles, cost me a grand total of $20. Here is some pics of the construction.
Had to make some new sleeves that were 3" long instead of the jeep bushings 2-5/8" sleeves.
They are roughly 4" longer from pivot to pivot, should give me an extra 2" of lift. 3/8x1-1/2" bar stock, tig welded.
More to come very soon...
cargs
3.0L
are you sure they are strong enough? lol.
88_Eddie
Raleigh, NC
i agree, those will break as soon as you leave the asphalt lol
j/k, how long did they take you? they look great
RacinNdrummin
Auburn, Wa
Took me about 3 hours total to build, and they are beef, thats for sure... but its one thing Ill never have to worry about!
Robert_1967
White Pine, TN
Nice build, is just me or does the front end need to be aligned??? the tires look like the top is out further then the bottoms..
Robert
sohc86-06
April 2011 STOTM Winner
1986 2wd ranger
ford ranger spo
man this is a great build
RacinNdrummin
Auburn, Wa
Little update...
I got the rear lift on with my shackles and add-a-leafs... gave me roughly 5" of lift. Ive been working on piecing the front lift together. I was going to use some 4" springs, a small spacer, 3/4" or something, 80-96 F150 quad-shock front shocks, My JD 3.5" drop brackets that I added another 1-1/2" to, and some homemade extended radius arms. Got the drop brackets and D35 back in:
Then I stumbled across a CL ad and contacted the guy...
Complete rancho 6" lift, Rancho extended radius arms w/brackets, drop pitman arm explorer 8.8 and D35... Scored it all for $300!
So I got everything pressure washed and painted up tonight, tomorrow im going to start putting everything in...
More tomorrow...
88_Eddie
Raleigh, NC
$300 for a 6 inch lift, front and rear axles and extended radius arms?!?!?!?! NICE find...looks like the previous owner played doctor with the 8.8 too, you lucky mofo, b2 looks great
